239
Feedback Tool - Let's improve OxygenOS together
  1. U1559544111474
    Cupcake May 30, 2020
  2. anurag_yadav718
    Cupcake May 31, 2020
  3. Artemus.
    Nougat May 31, 2020
    Artemus. , May 31, 2020 :
    Because why do you want 960fps?
  4. anurag_yadav718
  5. Artemus.
    Nougat May 31, 2020
    Nope. And seeing how many people can't seem to figure out how 480fps works imagine the amount of people posting that 960fps is worse. The same effect can be done in the editor with much better quality control.
  6. anurag_yadav718
  7. Artemus.
    Nougat May 31, 2020
    Should've saved that 52000 and waited for the 7T to be released.
  8. anurag_yadav718
    anurag_yadav718 , via OnePlus 7 Pro , May 31, 2020 :
    so you mean 7t is bttr then 7pro can you explain tha difference between 7pro nd 7t pro without Snapdragon 855 plus nd laser autofocus
  9. Artemus.
    Nougat May 31, 2020
    Can you explain why you want 960fps other than it's a feature that exists on a different device?
  10. anurag_yadav718
  11. Artemus.
    Nougat May 31, 2020
    For what? As I said, the same effect can be done in a video editor that negates all the special rules and requirements for such a thing.
  12. anurag_yadav718
    i just wanna knw what's the reason behind this why oneplus did not gives 960 fps in 7 pro what's tha reason
  13. Artemus.
    Nougat May 31, 2020
    Ask actual support, not here.
  14. snoopy_sanoop
    Eclair Jun 6, 2020
  15. ekhtiarapu18
    Cupcake Jun 6, 2020
    ekhtiarapu18 , via OnePlus 7 Pro , Jun 6, 2020 :
    my wifi band supports both 2.4 ghz and 5 ghz however on my device always 2.4 ghz bandwith remain connected where as my laptop also remain connected with 5 ghz bandwith after so many times trying i can not connect with 5 ghz bandwith it shows network not in range where my brother can connect with his device...why can't i??
  16. V1567751220895
    Cupcake Jun 12, 2020
    V1567751220895 , via OnePlus 7 , Jun 12, 2020 :
    After update beta14 on one plus7 found the brightness up-down issue & another issue is that Nova Launcher Prime's home button not working after a short period of running.So I request admin to fix both the issue within a very short period.Thnx.
  17. Z1541256958394
    Cupcake Jun 14, 2020
  18. Z1541256958394
  19. SydMoyaffor
    SydMoyaffor , via OnePlus 7 Pro , Jun 14, 2020 :
    Oneplus 7 Pro add camera filter like Oneplus 8 pro, Network Connection Improvement, calling issue low network condition, add new clock style, finger print animation new add , New Font style add
    Thank You OnePlus Never Settle
  20. rajeshpathikonda
    Cupcake Jun 15, 2020
    rajeshpathikonda , Jun 15, 2020 :
    Hi Team, I upgraded to Oxygen OS 10 in my OnePlus 5 just a couple of days back and have been facing a lot of issues since then. All Apps keep closing abruptly. My ringtone and vibration mode have been removed/unselected and I am not able to select it as every time I try doing that the settings just hangs and closes abruptly. So, I don't even get to know when I get a call now as my phone is always in silent mode. This is one of the biggest bugs I've been having so far. Kindly help in fixing this issue..
    G_Kirk_Fontaine_MBlG likes this.
