239
Feedback Tool - Let's improve OxygenOS together
  1. mooseh2002
    Gingerbread Jun 18, 2020
  2. saniulhossain
    Cupcake Jun 21, 2020
  3. domrik03
    Donut Jun 21, 2020
    domrik03 , via OnePlus 5T , Jun 21, 2020 :
    Android 10 was so disappointed because too much ram has been consume compare to the previous update 4gb of RAM was consume causing lag when you play high end game like pubg, call of Duty, rule of survival and mobile legends.. Try to check the remaining ram it's only 2gb the other was consumes because of the updates and all has been consumed by the OS is that an great update its big NO for me..
  4. domrik03
    Donut Jun 21, 2020
  5. domrik03
    Donut Jun 21, 2020
  6. domrik03
    Donut Jun 22, 2020
    domrik03 , via OnePlus 5T , Jun 22, 2020 :
    too much ram has been consumed and fast draining of the battery compare to the previous update android 9.please fix it in the next update as soon as possible if theirs new update upcoming for all the bugs.
  7. Artemus.
    Nougat Jun 22, 2020
    Artemus. , Jun 22, 2020 :
    There's no such thing as "too much RAM used".
  8. domrik03
    Donut Jun 23, 2020
    domrik03 , via OnePlus 5T , Jun 23, 2020 :
    Artemus.
    There's no such thing as "too much RAM used".​
    see it by yourself and try to compare the previous android 9 and android 10 they are to many bugs for this update android 10 some application has delays causing slow response especially when you play game and also some lagging issues when using chrome im sure they will not complain if they are no bugs for this update compare in android 9 version which is so fast no lagging issues after all and has minimal problems especially the battery also fast drain compare to the Android 9 version
  9. W1528733032414
    Cupcake Jun 26, 2020
  10. Rahul_Chowdhary
    Eclair Jun 26, 2020
    Rahul_Chowdhary , Jun 26, 2020 :
    Hello all,
    I am using OP6(10.3.4). I am unable to open digital well being from settings. Few days back I configured app timer for some of my apps now I am unable to open digital well being and alter the settings for app timer. Cant use whatsapp for more than 30mins as I had set timer for 30mins usage[e]1f614[/e]
    Can some1 plzz help me here with this
  11. Adg123456789
    Gingerbread Jun 27, 2020
    G_Kirk_Fontaine_MBlG likes this.
  12. Artemus.
    Nougat Jun 27, 2020
    Artemus. , Jun 27, 2020 :
    Don't expect any support (from the community) if you can't provide screenshots.
  13. subbuammu
    Cupcake Jun 28, 2020
  14. Artemus.
    Nougat Jun 28, 2020
    Artemus. , Jun 28, 2020 :
    Posting here won't do anything. This thread is letting people know about the feedback tool, not a place to report problems.
  15. domrik03
    Donut Jun 30, 2020
    domrik03 , via OnePlus 5T , Jun 30, 2020 :
    Don't update your phone to android 10 too many bugs has been detected. voice recorder has been affected ang operating system gives so much lag in the interface the battery drains so fast compare to the previous one android 9 they will never be additional update for us because this is the last update for the older one plus phone so disappointed to the one plus company time goes by still no update feedback to all queries about our phone one plus 5T
  16. domrik03
    Donut Jun 30, 2020
  17. Artemus.
    Nougat Jun 30, 2020
    Artemus. , Jun 30, 2020 :
    There's a simple solution to this predicament: factory reset. Android 10 is a huge change to the foundation of the Android OS and simply resetting the phone will fix most of the things. I've suggested this to everyone having these types of issues when the 6/6T got A10 and 90% of the time it fixed it.
  18. domrik03
    Donut Jun 30, 2020
    Artemus.
    There's a simple solution to this predicament: factory reset. Android 10 is a huge change to the foundation of the Android OS and simply resetting the phone will fix most of the things. I've suggested this to everyone having these types of issues when the 6/6T got A10 and 90% of the time it fixed it.​
    only 90% its useless they should have additional update for all the bugs they put in the update that is only solution of the probems not the reset thing.
  19. Artemus.
    Nougat Jul 1, 2020
    Artemus. , Jul 1, 2020 :
    Trust me... it works.
  20. G_Kirk_Fontaine_MBlG , via OnePlus 7 Pro T-Mobile , Jul 1, 2020 :
    domrik03
    Artemus.
    only 90% its useless they should have additional update for all the bugs they put in the update that is only solution of the probems not the reset thing.​
    I am on Android 10 and I did a factory reset earlier based on my media apps stopping and I have to restart (YouTube videos, podcast apps and music apps and it is all of them and it happens inconsistently)
    So should do over since I just received the lastest security update from Google?
    Quite annoying BTW
