Few issues i face with Noughat update
  1. akp2016
    Eclair Jan 7, 2017
    akp2016 , Jan 7, 2017 :
    I have updated my OnePlus3 to Noughat, their are few issues that I am facing.
    Firstly, battery gets discharged faster then it did for me on MM
    Second, Notification drop down on portrate mode is not in center aligned, refer screenshot.
    Third, Earphones buttons are not working to answer a call or to disconnect an ingoing call (audio tuner is set to, General enhancement, tried other too)
    used Samsung earphones, Apple Earphones, skull candy and Philips, none of it is working on call (working for controlling music)
    Fourth is Volume, I personally felt that overall phone volume (call amd messages) is quite low as compared to MM.
    Fifth, Data setting on phone shows to chose Sim1 or Sim2, rather then listing names I assigned to my both Sim for easy identification (may not be an issue but a feature request), refer screenshot
    Sixth, Equiliser does not have effect on the sound
  2. G_Kleant_Cupi_fLGd
    Donut Jan 7, 2017
    G_Kleant_Cupi_fLGd , Jan 7, 2017 :
    Notification bar its not centered because it depends on which side of the screen you pull it down left or right
    4tr4s and G_Ronak_Barman_NIuw like this.
  3. jaxYz
    Donut Jan 7, 2017
    jaxYz , Jan 7, 2017 :
    Equalizer Issue:
    Works fine on me, been using it for days
    Try using it while your headset is attached, also sometimes need to open settings - Audio Tuner to make it enable (does anyone facing this issue?)
    Vedant620 likes this.
  4. G_Ronak_Barman_NIuw
    Cupcake Jan 7, 2017
    G_Ronak_Barman_NIuw , Jan 7, 2017 :
    notification drop-down isn't an issue, it's a feature and it depends from which side you pull it down, battery backup is fine after two complete battery cycles(100%-0%)
    the only issues i have are that, while listening to music via earphones, and then opening Instagram, if you click a picture from the story mode, the sing resumes playing in loudspeaker and earphones both(faced the socially awkward situation) and second, sometimes, the phone gets all sluggish, and keyboard starts lagging.. and scrolling too.. so i have to reboot, and then it's normal again.. probably some cache dump issue. I hope an update will fix these.
  5. SimonRam
    Lollipop Jan 7, 2017
    SimonRam , Jan 7, 2017 :
    You can apply names for sims
  6. Gautam_Seth
    Froyo Jan 7, 2017
  7. you_weee
    Gingerbread Jan 7, 2017
  8. rammohangs
    Eclair Jan 26, 2017
    rammohangs , Jan 26, 2017 :
    The speaker at times doesn't work. Sound will not come. And then have to restart the phone. Is any one facing the same issue after the update???
    Rahul Rajeev likes this.
  9. Nabz123
    Cupcake Feb 5, 2017
    Nabz123 , Feb 5, 2017 :
    I am facing quite a few buggy issues with the update. hope another update or patch comes for this soon!!!!
  10. Shivanand5486
    Cupcake Feb 5, 2017
  11. Amiga4000
    Gingerbread Feb 5, 2017
    Amiga4000 , Feb 5, 2017 :
    which ones?
  12. Alpha Mike Foxtrot
    KitKat Feb 5, 2017
  13. Rahul Rajeev
    Cupcake Feb 5, 2017
    Rahul Rajeev , Feb 5, 2017 :
    Ringtone disappears Nd I have to reboot it to get it back and will vanish in a few mins... I tried wiping the cache and doing a factory reset. Problems still continues.can anyone help me with this becoz it's so much annoying to miss calls.
  14. G_mujeebullah_khan_Ognr
    Cupcake Feb 5, 2017
  15. Alpha Mike Foxtrot
    KitKat Feb 5, 2017
  16. Nabz123
    Cupcake Feb 10, 2017
    Nabz123 , Feb 10, 2017 :
    some of my apps stopped working, sometimes buttons press but don't action also my music player starts playing by it self randomly.
  17. Amiga4000
    Gingerbread Feb 10, 2017
    Amiga4000 , Feb 10, 2017 :
    so get Updates to the Apps, it is mostly Bugs in the App if they do stop or malfunction.
    my Apps keeps running in fine. but I use Just a few of them.
    all the Hardware Buttons do Work fine here, Software Button do Work OK, too. maybe if your App do use the system too much, it Blocks the System partly.
  18. Nabz123
    Cupcake Feb 20, 2017
    Nabz123 , Feb 20, 2017 :
    my apps are all updated. it just started to bug out after the software update.
