6
FiLMiC pro noise level
  1. mkoelsch Gingerbread Dec 18, 2018
  2. freal0s Cupcake Dec 20, 2018
    freal0s, Dec 20, 2018 :
    hopefully the dev will take a serious look on this issue, if u can't make other 3rd party apps work well with OP, then make your apps better
    1. Gimbal pairing support
    2. External mic option for video recordings
  3. mkoelsch Gingerbread Dec 23, 2018
    mkoelsch, Dec 23, 2018 :
    No clue if this is normal, but I got a message containing this text
    Let's keep the fingers crossed to see an improvement soon :)
  4. freal0s Cupcake Jan 1, 2019
    freal0s, Jan 1, 2019 :
    got the same feedback when i open up a support ticket..dun get your hopes too high..i think that's a reply template..haha
  5. icelangpo Cupcake Feb 3, 2019
    icelangpo, Feb 3, 2019 :
    it's 2019 and I hope they fix this. Also for some reason the auto white balance doesn't work, regardless of the environment it stuck at 5000k. Anyone else experienced this issue?
  6. DennisMiltz Donut Feb 3, 2019
    jbrulin likes this.
  7. icelangpo Cupcake Feb 3, 2019
    I can't view the video. I really hope that they fix this issue because I'm using my OP6 for my vlogs.
  8. DennisMiltz Donut Feb 3, 2019
    DennisMiltz, Feb 3, 2019 :
    yeah, youtube seems to have a problem right now with this video...
    It will not show up to me even though it's my own video
  9. mkoelsch Gingerbread Feb 7, 2019
    mkoelsch, Feb 7, 2019 :
    Nice video. It really underlines the problem we have with the lacking support of the camera 2 api :'(
  10. N1551458248997 Cupcake Mar 4, 2019
    N1551458248997, Mar 4, 2019 :
    I just ordered my 6T specifically for the camera quality with the Google Cam port (and the battery, lol). Has anyone tried the gimbal with this Google Cam port to see if there are issues as well? I was planning on purchasing Filmic Pro, but now you've got me considering other wise.
  11. icelangpo Cupcake Mar 17, 2019
    icelangpo, Mar 17, 2019 :
    It's been a year and there was a recent update but still no support for Filmic pro. :(
  12. mkoelsch Gingerbread Apr 12, 2019
  13. cmaring Cupcake Jun 14, 2019
    cmaring, Jun 14, 2019 :
    Any solution yet? It's mid 2019 and I'm still having the same issue. The videos suck. I'm using Filmic Pro with DJI Osmos II.
  14. 77cats Cupcake Jun 20, 2019
    77cats, Jun 20, 2019 :
    Same here. Half a year later, Oneplus 7 Pro 5G and Filmic shows some bad Chroma noise. The internal noise reduction setting in Filmic Pro does nothing for this and filming on the lowest ISO only keeps in check the more normal noise.
    The default video mode has no Chroma noise (4K@60fps), minimum noise in a low light test and only in shadows. I know that the guys at Filmic do their best, so it's all up to the manufacturers, and to OnePlus.
  15. L1528584966030 Cupcake Jun 25, 2019
