15
Finally ordered Tripod for OnePlus One
  1. ChoosyMoron
    Honeycomb Mar 3, 2015
    ChoosyMoron , Mar 3, 2015 :
    Yes..have been waiting for this since a long time but really could not get time to figure it out but seems like its happening now. Just wanted to share with you guys that I have recently ordered a Tripod with the mobile mount for my OnePlus One. I am an editor by profession & would love to have a phone with 4k recording capabilities and a tripod to make some really good videos.
    After searching & little bit researching I found these & thought these are pretty cheap and good for my requirements.
    1. Photron Stedy Pro 450 Tripod
    2. Fotopro SJ-80 Mobile Phone Stand
    I have ordered these from Amazon India as I am from Mumbai & once I get them I will update on the quality and try to review these over here..Also will shoot some stuff & share it here..Peace...
    And forgot to mention the total came up to just Rs.1400/- :p
    So finally it has arrived & after using it for almost 3 days I feel its really worth Rs.1000 & the mobile holder for Rs.400 is just the best you can get in the market.Let me start with the mobile holder itself..
    Fotopro SJ-80 Mobile Phone Stand.
    IMG_20150305_203301.jpg IMG_20150305_203308.jpg IMG_20150305_203320.jpg IMG_20150305_204943.jpg IMG_20150305_204951.jpg
    I Love this mobile holder its just so perfect to fit in any tripod. It does not feel cheap plastic at all. I tried shooting with the OnePlus One (5.5 inch) & the Motorola Nexus 6 (6 inch) both the phones were really easy to slide in. It really grips your phone well. Also I would like to add that both my phones had their own covers and still the grip was perfect. The clipping part which goes to the tripod is built really well no issue with that. I was able to screw and unscrew without any problems. They have also provided some cushion for your phone to rest, so that the phone won't get scratched from the sides.
    Overall I would rate it 5/5 keeping in mind that the cost is really cheap.Let's move on to our tripod now.
    Photoron Stedy Pro 450.
    IMG_20150305_211210.jpg IMG_20150305_211304.jpg IMG_20150305_203425.jpg IMG_20150305_203627.jpg
    I would say that this tripod is really good for mobile phones but I'm sure it wont be able to handle entry level DSLR's though I tried some point to shoot camera's like Nikon & they worked well.
    I am going to start the review from the bottom to the top of the tripod..
    • I'm impressed with the quality of legs of the tripod. The entire mechanism to unclip & clip the legs is really smooth. I am getting a really good height to shoot and they are easily adjustable. Moving above...
    • The sponge grips are really good gives a nice grip while framing the shots.
    • The header can easily be extended to a great height & is really helpful while taking shots at certain table levels.
    • The up & down tilt mechanism using the bar provide is good no issues with that. I was able to pan shots from top to bottom easily..
    • Now the main trouble, I guess this is the only disadvantage so far in this tripod that really got me thinking but then I though well its for 1k what else do you expect from such a product. The pan from left to right or vice versa really depends on how the ball rotation is made on the tripod & for this tripod I'm finding a lot of jerks in between while panning. Still I'm trying to do more PAN shots and test this out but for now this is the only issue which I am facing for now with this tripod.
    So finally here is some test images I took with the tripod of my Nexus 6.
    Video made using this tripod (Devices used Nexus 6 and OnePlus One):-
    shamuko69, ritz905, 2emkay and 12 others like this.
  2. Pradeep Bhat
    Gingerbread Mar 3, 2015
  3. sonygoup
    Honeycomb Mar 4, 2015
  4. azp3
    Jelly Bean Mar 4, 2015
  5. Toulouse
    KitKat Mar 4, 2015
    Toulouse , Mar 4, 2015 :
    1400 INR is about 20 EUR right? If so, then it's a good deal. There are very cheap tripods on Ali Express too
  6. Hiraeth
    Ice Cream Sandwich Mar 4, 2015
    S0bek and 16por9 like this.
  7. M1cks
  8. DaxNagtegaal
    Marshmallow Mar 4, 2015
  9. M1cks
  10. ChoosyMoron
  11. ChoosyMoron
    ChoosyMoron , Mar 4, 2015 :
    Looks good :)
    Hiraeth likes this.
  12. mvmsaikrishna
    mvmsaikrishna , Mar 4, 2015 :
    Nice. Just post the review. May be I will get one :)
  13. ChoosyMoron
    Sure let the thingy arrive :p & hopefully I can write about it here...with some pictures...
  14. wasser216
    Gingerbread Mar 4, 2015
  15. Hiraeth
    Ice Cream Sandwich Mar 5, 2015
    Hiraeth , Mar 5, 2015 :
    Thanks! I used a "Proline Carbon Fiber Tripod, that costed me 180) and a 5 dollar Universal phone mount. :eek: Such different prices lol!
  16. 16por9
  17. ChoosyMoron
    Honeycomb Mar 7, 2015
    ChoosyMoron , Mar 7, 2015 :
    The tripod has arrived I have got all the pictures clicked..Writing the review will update the thread by Monday..Just busy with some work....Also shooting some video if that goes live we will use that as a reference :)
  18. william-bailey
    Gingerbread Mar 7, 2015
  19. mvmsaikrishna
    Ice Cream Sandwich Mar 7, 2015
  20. shrey1992
