5
Camera Finally Solved auto focus Camera issue after upgrade one plus 3
auto focus Camera issue after upgrade one plus 3 , Help you
  1. Yes
    3 vote(s)
    30.0%
  2. No
    7 vote(s)
    70.0%
Multiple votes are allowed.
  1. Abhimanyu Mane
    Honeycomb Oct 22, 2017
    Abhimanyu Mane , Oct 22, 2017 :
    I checked it man... That's the only supplier around here right now... and even this camera module is out of stock at lot of Oneplus's Service Centers....
    You know Oneplus charges around ₹4000/- to replace it.... F.U.CK.I.N.G Loot man.....
    #41
  2. Abhimanyu Mane
    Indeed...
    If this is gonna blow up like this than better learn lesson from it....
    #42
  3. Sridhar Ananthanarayanan
    Lollipop Oct 22, 2017
    Sridhar Ananthanarayanan , Oct 22, 2017 :
    I would still suggest that you backup all your files Tina pc, take a nandroid backup, and wipe everything. sideload a custom ROM, say Resurrection Remix ROM, and see if it helps.
    #43
  4. Abhimanyu Mane
    Will try it man....
    [e]1f44d[/e]
    #44
  5. Sridhar Ananthanarayanan
    #45
    Abhimanyu Mane likes this.
  6. mehdi63_1
    Donut Oct 22, 2017
    mehdi63_1 , Oct 22, 2017 :
    Actually it was my own strategy too, but at that same update that these problems occurred i was fooled and updated immediately :|
    #46
  7. Abhimanyu Mane
    #47
  8. Abhimanyu Mane
    So be wise next time.... This apply me too...
    #48
  9. Sridhar Ananthanarayanan
    see, the issue has not affected all units. it seems to have affected only some of them unfortunately. now if the company has provide a software fix, that would be great.
    #49
  10. Sridhar Ananthanarayanan
    #50
  11. Abhimanyu Mane
    Noh Man....
    I don't understand difference between these two device.....
    I was the one of them who had regrated last year for buying OnePlus 3 when it got launched and just after few months 3T came out.... It's same situation like currently OnePlus 5 user's gonna feel... so how can I forget difference between 3 and 3T......
    #51
  12. Sridhar Ananthanarayanan
    I am just guessing here. it is quite possible that OnePlus was hosting the 3T firmware on the link for 3 at some point, and when they realised the error, they corrected the links. those who downloaded the wrong firmware, ended up having this issue.
    this is just a theory which could well be wrong because firmwares are supposed to have inbuilt check to ensure that they only install on the correct device.
    this is the name of the ROM I currently have installed:
    OnePlus3TOxygen_28_OTA_056_all_1709231856_adf3e427234b471f.zip
    this is basically OOS 4.5.0.
    what is the name of the zip that you flashed?
    #52
  13. Abhimanyu Mane
    Yeah that's possible....
    But talked with someone who just recently brought this phone and got hit with this problem it's just last weeks thing....
    So I don't think so this fits in current data available with us....
    #53
  14. Sridhar Ananthanarayanan
    so the problem is with both 3 and 3T?
    is so, then even the batch theory that I was talking about would be wrong.
    #54
  15. Abhimanyu Mane
    Mine one is OnePlus 3 and 4.5.1 version
    "OnePlus3Oxygen_16_OTA_057_all_1710122310_f5da2d4b1f194f4e.zip"
    This is name of zip I used....I guess I tend to delete files so find it deficult to get it again
    #55
  16. Abhimanyu Mane
    Yeah man....
    Both phone having this problem.....
    #56
  17. Sridhar Ananthanarayanan
    what could have actually gone wrong?
    the issue has affected only some devices.
    I can only think of one thing - there was some incompatibility in the original links that messed up the devices. they must have replaced the original files with the corrected ones without changing the download link.
    can't think of anything else that explains the problem.
    #57
  18. Sridhar Ananthanarayanan
    I have the 4.5.1 zip too and the names are quite different.
    #58
  19. Abhimanyu Mane
    Okay....
    Let's gets to execution now
    1. I had updated my phone in August 17 from that time I ma facing this problem.
    2. Some people around here done it very recently than got this problem.
    So your this theory don't fit here....
    #59
  20. Abhimanyu Mane
    As I mentioned earlier mine one is OnePlus 3...
    #60
