Finger lock is not appropriate
  1. Kshitijdwivedi
    Cupcake Sep 7, 2019
    Kshitijdwivedi , Sep 7, 2019 :
    I have set the finger lock, but still I am able to open my phone without using it..anybody can access my phone even though it has security lock. What's that about ??
  2. Cervantes
    Lollipop Moderator Sep 7, 2019
    Cervantes , Sep 7, 2019 :
    Hi
    What other security options do you have enabled
  3. Kshitijdwivedi
    Cupcake Sep 7, 2019
  4. Matt 80
    Lollipop Sep 7, 2019
    wlonsdale likes this.
  5. Cervantes
    You have a watch connected by bluetooth
    Kshitijdwivedi likes this.
  6. Budruel
    KitKat Sep 7, 2019
    Budruel , Sep 7, 2019 :
    Do you have a twin brother?
  7. sushanth_goud
    Froyo Sep 10, 2019
    sushanth_goud , Sep 10, 2019 :
    Go To "Settings">>>Click on "Security & Lock screen">>>Select "Smart Lock">>>Enter Device "Pin or Password">> Now you see 4 options.
    1st Step: In Smart Lock Tap on "On-Body Detection" and disable it.
    2nd Step: In Smart Lock Tap on "Trusted places" and delete any places if you have added as your device will be unlocked without any Password when you are at that place.
    3rd Step: In Smart Lock Tap on "Trusted Device' and delete any devices that you have added as your device will be unlocked without any Password when these devices are nearby your mobile.
    Please check by doing the above steps and let me know.
  8. Kshitijdwivedi
    Cupcake Nov 10, 2019 at 8:25 PM
