finger print is not working via OnePlus 8
  1. N1593253919227
    Cupcake Aug 14, 2020
  2. HVS_RAW_00747
    HVS_RAW_00747 , via OnePlus 8 , Aug 14, 2020 :
    Bro
    Try the following things and update here if it does not solve the problem.
    Try to re register your fingers after deleting the older scans
    Try to clean your fingers and driest when you register them
    Clean the scanner
    .if it still doesn't work
    Then as a last measure
    Take a backup of everything
    And factory reset your device
    Hope this helps....
