[Submitted] Finger print not visible
  1. Abhishek.001
    Honeycomb Aug 28, 2021
    Abhishek.001 , Aug 28, 2021 :
    Finger print not visible on ambient display.
    OS 11 OnePlus 6t
    Pls do the needful
    There lots of bugs
    We need some polished updates in future.
  2. Ankita_S.
    OnePlus Bug Hunter Staff Member Aug 29, 2021
    Ankita_S. , Aug 29, 2021 :
    For analyzing this better we would need more details & to get this sorted out at the earliest. We've dropped you a personal message and would request you to respond to the same.
    Regards,
    Ankita
    Abhishek.001 likes this.
  3. P1565455511445
    Cupcake Sep 20, 2021
    P1565455511445 , via OnePlus 6T , Sep 20, 2021 :
    I had the same issue. I updated to stable Oxygen OS 11 few weeks ago. It was working fine until the fingerprint is gone vanished from my lockscreen. When I checked in the security settings' fingerprint section, all the fingerprints that I had set before were gone and I have to re-register my fingerprints again.
    Hope this helps!!!
    Guess this is a bug with the Oxygen OS 11, which some instances triggers to delete all the fingerprints set on the device causing the disappearance from the lockscreen.
