Finger print scanner via OnePlus 7T
  1. raki1606
    Cupcake Jul 26, 2021
    M1603207670211 likes this.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 26, 2021
    Dresa91 , Jul 26, 2021 :
    Since when does this happen?
    Are you using a protector film?
    Did you remove the fingerprints and add them again?
    McJader likes this.
  3. McJader
    Marshmallow Jul 26, 2021
    McJader , Jul 26, 2021 :
    if it's not happening only in apps, most probably a problem in app locker.
    Here's how I fixed it
    Go to settings>apps and notifications>see all apps>three dots on top right>show system apps>then search for applocker and select it>storage and cache>clear storage and clear cache>restart your device
    Dresa91 likes this.
  4. raki1606
    Cupcake Jul 28, 2021
    raki1606 , via OnePlus 7T , Jul 28, 2021 :
    Not resolved
  5. raki1606
    Yes I changed finger print
  6. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 28, 2021
    Dresa91 , Jul 28, 2021 :
    What OxygenOS version are you currently using?
    Did you clear cache in recovery?
  7. raki1606
    Cupcake Jul 29, 2021
    raki1606 , via OnePlus 7T , Jul 29, 2021 :
    Oxygen 11 and cleared the cache
  8. raki1606
  9. pablofg1978
    Head Moderator Head Moderator Jul 29, 2021
    pablofg1978 , Jul 29, 2021 :
    Thread merged
    Please do not create duplicate threads
    McJader likes this.
  10. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 29, 2021
    Dresa91 , Jul 29, 2021 :
    What OxygenOS version exactly?
  11. T1627455082956
    T1627455082956 , Jul 29, 2021 :
    I'm using Oxygen OS 11.0.2.1HD65AA. Fingerprint scanning won't work in 60hz. When I revert to 90hz, fingerprint scanner works fast.
    McJader likes this.
  12. Dresa91
    Can you please remove the fingerprints and readd them again?
  13. T1627455082956
    I did it just now. Same thing. You can register your fingerprint, no problem. But it won't be recognized in 60hz. Reverted to 90hz and works fine.
  14. Dresa91
    Are you using a screen protector?
  15. T1627455082956
  16. Dresa91
    And did you register the FPS with 60hz?
    can you please clear cache in recovery?
  17. T1627455082956
    T1627455082956 , via OnePlus 7T , Jul 29, 2021 :
    Yes. I registered the FPS with 60hz.
    How would I clear cache in recovery?
  18. Dresa91
    Here:
    Wipe Cache in OnePlus 7 Pro/7T Pro/7T/7
    Step 1:
    Make sure to switch off your phone.
    Step 2: Press & hold the power and volume down key at the same time until seeing the OnePlus logo, release all buttons.
    Step 3: Select the language from the list.
    Step 4: Tap on Wipe data and cache.
    Step 5: Tap Wipe cache.
    This message appears: Cache will be wiped, continue?
    Step 6: Tap Yes.
    You can see a “Wipe success” message when complete the process.
    Step 7: Tap Reboot.
  19. T1627455082956
    Thanks. On it.
    Dresa91 likes this.
  20. T1627455082956
    Cleared the cache. Still the same, fingerprint is not recognized in 60hz but works ok with 90hz.
