Finger print sensor and home button stopped working suddenly on OP 3T
  1. Tj32
    Froyo Jan 28, 2020
    Tj32 , Jan 28, 2020 :
    Fingerprint sensor and home button doesn't work and do not give me any option to change or add fingers anymore. I tried *#808# test. PFA result.
    Is this somekind of a trick by OnePlus to upgrade the device?
    I'm but I'm being frank n seeking for resolution ASAP
  2. Ziertus
    Froyo Jan 28, 2020
    Ziertus , Jan 28, 2020 :
    Seems like the sensor may have malfunctioned. My sensor is still fine, hardware will wear out with time and the 3T is pretty old now. Only problem I have with my 3T is battery drain, but that is to be expected after a couple years.
  3. Paschfire
    KitKat Jan 29, 2020
    Paschfire , via OnePlus 3T , Jan 29, 2020 :
    How exactly is this a trick from OnePlus? That's ludicrous.
    HW fails, breaks. Take or send your device into a OnePlus service centre for inspection of possible.
  4. Ziertus
    Froyo Jan 29, 2020
    Ziertus , Jan 29, 2020 :
    How dare you blindly place your faith in corrupt companies!!! Obviously this is a 1+ scam to get us to buy their newest phones with their super quick release schedule. Tampering device quality shows that they are frauds! /s
  5. Paschfire
    KitKat Jan 29, 2020
    I hope you're just being sarcastic. Otherwise. You might want to consider loosening the strap on your tinfoil hat, I think it's on way too tight.
  6. Ziertus
    Froyo Jan 29, 2020
    loool, I even put a /s just in case man.
    Paschfire likes this.
  7. T1580212450041
    Cupcake Feb 3, 2020
    T1580212450041 , Feb 3, 2020 :
    Ok i got it
  8. Tj32
    Froyo Feb 14, 2020 at 3:14 PM
    Tj32 , Feb 14, 2020 at 3:14 PM :
    I fixed it myself.. went to recovery mode, cleared device cache and it got fixed.. looks like there is a lot of cache thats tricked the sensor.. Now its working fine. I think people can guide with troubleshooting instead of assuming things and discussing something off topic!
