5
Fingerprint after Nougat
  1. exis_tenz
    Gingerbread Jan 5, 2017
    exis_tenz , Jan 5, 2017 :
    The fingerprint-scanner is a disaster, but only AFTER the update to Nougat (stock rom, rooted).
    8 out of 10 times it is no more recognized. However I try. Did many re-set-ups, all not helping.
    In MM it worked perfectly so wouldn't say it's a hardware thingy. Really frustrating.
    Especially when driving. You don't want to be typing codes or drawing patterns then.
    FIX THIS ONEPLUS!
  2. borat
    borat , Jan 5, 2017 :
    no issues here. phone never rooted.
    stop complaining and go back to stock
  3. w4ri0ck
    w4ri0ck , Jan 5, 2017 :
    I have no issue with fingerprint in Nougat
    ps.
    especially while driving don't use you phone
  4. borat
    lol. don't watch movies while driving. especially not horror ones. u might crash. lol lol
  5. puspakpatnaik
    Eclair Jan 5, 2017
    puspakpatnaik , Jan 5, 2017 :
    Fingerprint issue is even there in Android M version. This may be due to the placement of home and fingerprint scanner on same button.
  6. Bartnl
    Lollipop Jan 5, 2017
    Bartnl , Jan 5, 2017 :
    Do a clean flash of the rom (1,4GB version) after clearing the system, data and cache.
    As you are rooted you must have TWRP installed, so you should know how to do this.
    Absolutely no problems with the scanner. Feels even more snappier.
  7. Bartnl
    Says who?
  8. exis_tenz
    Start reading: I am on stock!
  9. Gengel79
    Froyo Jan 5, 2017
    Gengel79 , Jan 5, 2017 :
    Also no problems with the fingerprintscanner after the update to nougat. Works perfectly fine
  10. exis_tenz
    Okay. Got the message. Should do a clean flash :-(
    So. What to do not having to set up everything new, which parts of a Nandroid can I put back in order to not have to set up accounts, settings, widgets etc. etc.?
  11. Deactivated User
    Jan 5, 2017
  12. inffy
    KitKat Jan 5, 2017
    inffy , Jan 5, 2017 :
    Well the idea with the clean flash is that you start from scratch and not restore from a backup...
  13. SimonRam
  14. oneplusknusper
    Eclair Jan 5, 2017
    oneplusknusper , Jan 5, 2017 :
    And to keep the universe in balance - works absolutely flawless here, 10 out of 10 tries get recognized perfectly fine. Stock Oxy 4, not rooted.
  15. exis_tenz
    Yes. Rooted. I guess that's basically the first reason why 50% of the folks buy a OP.
  16. G_Paul_Davis_JVBe
    w4ri0ck likes this.
  17. shubham8166409
    Froyo Jan 5, 2017
    G_Ananth_krishna likes this.
  18. G_manorath_kawathekar_LT
    Cupcake Jan 5, 2017
  19. Greedyfly
    Eclair Jan 5, 2017
    Greedyfly , Jan 5, 2017 :
    Has Nougat been fully rolled out on non rooted phones now? If so, anyone have any ideas how to get it?
    Apologies if this is a stupid question but this is my first reply (I need 5 because I need help with another issue also involving recent contacts vs favourite contacts on the shelf)
  20. bigbug2016
    Eclair Jan 5, 2017
