2
Fingerprint Scanner issue
  1. G_Devdan_Gaikwad_mCxR
    Cupcake Oct 20, 2019
    G_Devdan_Gaikwad_mCxR , Oct 20, 2019 :
    Hello, I updated the new Oxygen is with Android 10 before 2 days.
    after this update, getting few issues, like, the apps which use the fingerprint scanner to open, for few of them, this scanner is not appearing on the screen even after the fingerprint is enabled for the application. in my case, I am trying to unlock the iMobile ( ICICI bank application) but on the login page, fingerprint is not appearing. same for the other banking apps as well ( Citi, RBL etc)
    can you please check and suggest if something is wrong?
    O1567443271504 and Simplyroba like this.
  2. Simplyroba
    Donut Oct 22, 2019
    Simplyroba , Oct 22, 2019 :
    i have the same issue on every external app. Just oneplus apps are working with the fingerprint Sensor (for example: App Locker)
  3. shafaatkhan007
    Cupcake Oct 22, 2019
    shafaatkhan007 , Oct 22, 2019 :
    I am also facing this issue with HDFC mobile banking app. OP team, please help to fix this as i use this feature a lot and now facing issues due to this.
  4. O1567443271504
  5. Liehjan
    Lollipop Oct 22, 2019
    Liehjan , Oct 22, 2019 :
    Is you apps updated to work with android 10?
    G_Devdan_Gaikwad_mCxR likes this.
  6. Liehjan
    Are you sure the apps you use are 100% android 10 supported already?
  7. Simplyroba
    Donut Oct 22, 2019
    Simplyroba , via OnePlus 7 , Oct 22, 2019 :
    No not sure that every app is already supporting android 10. but I think paypal is big enough and at least the Playstore should support android 10. Activating the fingerprint in the Playstore app lets it crash immediately.
  8. G_Devdan_Gaikwad_mCxR
    G_Devdan_Gaikwad_mCxR , Oct 22, 2019 :
    Hi... thanks for your reply.
    Actually I am not sure that every banking app ( which I am having) has Android 10 support but one thing is there like, I have one friend who uses One Plus 7. She got the same update and even after update, her apps are supporting to fingerprint sensor while logging in. I will check with application support to the Android 10 but still if 7 is working fine, then why not with 7 Pro?
  9. jasemanONE
    Gingerbread Oct 22, 2019
  10. Gav_W86
    Starting Point Expert Oct 22, 2019
    Gav_W86 , Oct 22, 2019 :
    uninstall and re-install the app.
  11. ckithika
  12. G_Devdan_Gaikwad_mCxR
    Yes.. I did that as well... no difference. it's the same.. didn't work
  13. G_Devdan_Gaikwad_mCxR
    Yes.. I did this.. but even after that, I am not getting the scanner on the login screen..
  14. shafaatkhan007
    It was working after updating to Android 10 (Oxygen OS 10.0.0) but not working after updating to Oxygen OS 10.0.1
  15. sid014
    Cupcake Oct 23, 2019
    sid014 , Oct 23, 2019 :
    Hi Devdan,
    I am also facing the same issue, did you got any solution yet for this??????
  16. jasemanONE
    Gingerbread Oct 23, 2019
    jasemanONE , Oct 23, 2019 :
    I hate to suggest this...but....if the financial institution you are having issues with does not have an answer, and you cannot live with this issue, then you may have to do a factory reset WITHOUT letting any backed up apps reinstall on their own! After doing the reset make sure to install all your apps one at a time manually. I'm willing to bet that this will fix your problems. If it doesn't then it's the apps themselves. YMMV
  17. Simplyroba
    Donut Oct 28, 2019
    Simplyroba , via OnePlus 7 , Oct 28, 2019 :
    hi guys,
    for everyone who do not want to do a factory reset. what for me worked was to not only delete all fingerprints, but also to deactive the complete security by deleting the pin, password or pattern (what ever you are using). this does reset a few things in the android system and solved the problem for me. I hope this helps someone!
    shafaatkhan007 likes this.
  18. shafaatkhan007
    Cupcake Oct 29, 2019
    shafaatkhan007 , Oct 29, 2019 :
    thanks buddy, it worked for me as well[e]263a[/e]️
    Simplyroba likes this.
