Other Fingerprint scanner not working after reboot
  1. Nachtkruipert
    Eclair Aug 5, 2021
    Nachtkruipert , Aug 5, 2021 :
    Hi folks,
    Today when I put a new cover on my 9 pro, OS 11.2.8.8.LE15BA, it rebooted. No problem their.
    But, yes there is one, now the fingerprint scanner will not accept my fingerprint anymore.
    Just in case, did another reboot and I have even registered my fingerprint again.
    The one thing I do did a few days back was install a glass screenprotector. But after I installed it the fingerprint scanner still worked fine. So not thinking that will be the issue.
    Any help.tricks and or tips are very welcome.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 5, 2021
    Dresa91 , Aug 5, 2021 :
    What screen protector?
    Helder_DAlmeida likes this.
  3. Nachtkruipert
    Eclair Aug 5, 2021
    Brandname is: Rosso
    Type is: tempered glass 9H for the 9 pro
    And the fingerprint scanner did worked after I installed it.
  4. Dresa91
    Can you please remove the fingerprints again, clear cache in recovery and add them again?
  5. Dresa91
  6. Nachtkruipert
    Eclair Aug 5, 2021
  7. Dresa91
    Can you test it in safe mode?
    Do you have another screen protector?
  8. Nachtkruipert
    Eclair Aug 5, 2021
    Weird thing is that it does add the fingerprints. No problem there. Just not able to unlock the phone
  9. Dresa91
    Does it work in apps?
  10. Nachtkruipert
    Eclair Aug 5, 2021
    Same thing... will not unlock my phone in safe mode either.
    And no I don't have any other screen protector. But can always buy one.
  11. Dresa91
    Can you please check it in apps like banking, app lock, etc
  12. Nachtkruipert
    Eclair Aug 5, 2021
    Did that and none of the apps that use my fingerprint can use it anymore. Crap... this is getting bad now.
    Some apps doesn't see the fingerprint and some go crazy and give an error that I have tried to many time but that is before I even touch the screen.
  13. Nachtkruipert
    Eclair Aug 5, 2021
    Did an other reboot and now I have lost one home screen and the google news feed when swiping from left to right...\
    Ok... restored all that... Still no working fingerprint scanner, anywhere.
    Now it says, to many attempts and I have to give in my code. And that is without me even touching the screen when I try to unlock it
  14. Dresa91
    Okay,.. did you try a reset?
  15. Nachtkruipert
    Eclair Aug 5, 2021
  16. Dresa91
    Yes.
    Please backup your data before :)
  17. Nachtkruipert
    Eclair Aug 5, 2021
    Running a back up right now. After that I will reset the phone. Getting nerveus here, just a bit.
    Dresa91 likes this.
  18. G_V._M._sKKA , via OnePlus 9 Pro Pine Green , Aug 5, 2021 :
    It is allways the same after each Update and/or reboot. Starts working again after some time/days.
    Dont waste too much time trying to solve it...
    Nothing of what is mentioned here will work.
    You can search in the forum and will find many users with the same issue.
    I have the same as well
    and already reported the Bug.
    But i guess they have more important stuff to fix for this waste of money.
  19. Dresa91
    Okay. Let me know if this helped.
  20. Nachtkruipert
    Eclair Aug 5, 2021
    Still no luck... did a full reset. It did register my fingerprint. But it will not unlock the phone
