Other Fingerprint scanner not working after reboot
  1. Nachtkruipert
    Eclair Aug 5, 2021
    Nachtkruipert , Aug 5, 2021 :
    I have rebooted my phone in the past without any problem. So could you post a link to some of the topics that had this problem?
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 5, 2021
    Dresa91 , Aug 5, 2021 :
    Then I have three suggestions:
    1. Submit a bug report via https://forums.oneplus.com/feedback/ And wait for the next update
    2. Remove the screen protector and try again
    3. Visit a service center and let your device getting checked
    Helder_DAlmeida likes this.
  3. G_V._M._sKKA , via OnePlus 9 Pro Pine Green , Aug 5, 2021 :
    Just search for "fingerprint" in the forum.
    But again, my understanding ist, that there is nothing that could fix the issue.
    For me it starts working again after some time without doing anything specific.
    Just report a Bug and See if it works again after some time for you as well.
    Dont send it to the Service Center... This is most likely a Software bug
  4. Nachtkruipert
    Eclair Aug 5, 2021
    Nope... didn't fix the issue. Restoring the phone and data right now.
    After that I will give it a few days and see if G_V._M._sKKA is right. Hope he/she/it is.
    If that doesn't solve it, I will take the screen protector and see if that is the problem. Just in case.
  5. Dresa91
    Yeah, as I wrote here:
  6. Nachtkruipert
    Eclair Aug 5, 2021
  7. Dresa91
  8. Nachtkruipert
    Eclair Aug 5, 2021
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 6, 2021
    Dresa91 , Aug 6, 2021 :
    Yes, some can.
  10. Nachtkruipert
    Eclair Aug 6, 2021
    Best Answer
    Dresa91 likes this.
  11. Dresa91
    So the Screenprotector has caused the problems ?!
  12. Nachtkruipert
    Eclair Aug 6, 2021
    Nachtkruipert , via OnePlus 9 Pro , Aug 6, 2021 :
    Yes it seems so. After I removed it I was able to unlock the phone and it also works in all the apps that use it... I will see what what will happen in the next few days.
    Dresa91 likes this.
  13. Dresa91
    Okay:)
    Do you have a link to the screen protector?
  14. Nachtkruipert
    Eclair Aug 6, 2021
    Dresa91 likes this.
  15. Dresa91
  16. Nachtkruipert
    Eclair Aug 6, 2021
    And I even read the instructions for applying that thing. Can you imagine... An IT nerd, reading instructions. 🙃
    Took my time and made sure it was done as good as possible.
    Dresa91 likes this.
  17. Akshat Sehgal
    Ice Cream Sandwich Aug 6, 2021
  18. Akshat Sehgal
    Akshat Sehgal , via OnePlus 9R Lake Blue , Aug 6, 2021 :
    Knew it. Get a screenprotector from some known brands like spigen. Low quality ones will always cause some issue.
    #38
  19. Dresa91
    Yeah..
    Now I hope you don’t face the issue again:)
    #39
  20. Nachtkruipert
    Eclair Aug 6, 2021
    Nachtkruipert , Aug 6, 2021 :
    Well I did bought one that was more expensive. Just to avoid this problem and they even mentioned in the manual that i might have to re-register my fingerprints. And I did my research first.
    #40
    Dresa91 likes this.
