Fingerprint sensor and home button suddenly stopped working.
  1. utkarshrajsingh
    Froyo Nov 5, 2015
    utkarshrajsingh , Nov 5, 2015 :
    I came back from my college today.
    Everything was fine.
    Then i put my OP2 on the table. I cleaned it with a moist tissue, and while i was cleaning the screen (with temper glass) the hardware button suddenly stopped working, i use hardware button with on screen buttons.
    It does not work at all. Like its dead.
    Neither the fingerprint sensor works and nor the hardware home button. The two capacitive keys work fine though,ie back and multitask button.
    I have done a full factory reset, but its still not working.
    Its a little more than a month old.
    What should i do?
  2. Thephoneofphones
    Jelly Bean Nov 5, 2015
  3. utkarshrajsingh
    Froyo Nov 5, 2015
    I told you its more than a month old.
    So they can't replace it. They can only repair it.
  4. You237
    Honeycomb Nov 5, 2015
    You237 , Nov 5, 2015 :
    That's what an RMA is.
    Also, have you tried flashing a new update/kernel?
    mkernbach and Gaurav Rohilla like this.
  5. mkernbach
    KitKat Nov 5, 2015
    mkernbach , Nov 5, 2015 :
    Let the battery die. Then it should work again. There are few threads about.
    Gaurav Rohilla likes this.
  6. utkarshrajsingh
    Froyo Nov 5, 2015
    No, I have not tried any kernels.
    It's OS 2.1.1 though.
    It's not rooted. But the bootloader is unlocked.
  7. utkarshrajsingh
    Froyo Nov 5, 2015
    The battery was almost dead. Now its charging.
  8. mkernbach
    KitKat Nov 5, 2015
  9. dinjesk
    KitKat Nov 5, 2015
    dinjesk , Nov 5, 2015 :
    i got the same problem yesterday, try booting your phone in safe mode.
    when i did this the home button was working in safe mode.
    then just reboot normal.
    hope it works for you
  10. utkarshrajsingh
    Froyo Nov 5, 2015
    Tried safe mode.
    Seems like a hardware issue. :/
  11. dinjesk
    KitKat Nov 5, 2015
    to bad, hope all the best for you
    utkarshrajsingh likes this.
  12. utkarshrajsingh
    Froyo Nov 5, 2015
    I'll visit the service center on Saturday and get this fixed.
  13. Thephoneofphones
    Thephoneofphones , Nov 5, 2015 :
    Then get it repaired.
  14. X_mg
    Froyo Nov 5, 2015
    X_mg , Nov 5, 2015 :
    Do you have a style swap cover on your op2?
  15. batranikhil
    Cupcake Nov 6, 2015
    batranikhil , Nov 6, 2015 :
    I got the same problem this morning. The fingerprint sensor and home button suddenly died.
    Another friend of mine is facing this issue since day wednesday now. Whats happening ? Maybe one of the moderators can comment on it..
    Can anyone point this to the moderators please..
  16. Naman Bhalla
    Recognized developer Recognized Developer Nov 6, 2015
    Naman Bhalla , Nov 6, 2015 :
    Hi !!
    Suggest you to reflash full rom via stock recovery.It should work,atleast works for some.
    If it doesn't work,contact OnePlus Support.
    Thanks. :)
  17. batranikhil
    Cupcake Nov 6, 2015
  18. utkarshrajsingh
    Froyo Nov 6, 2015
    utkarshrajsingh , Nov 6, 2015 :
    Please, forward the instructions for flashing the full rom through stock recovery.
    I cannot find the link to full rom that can be flashed through stock recovery.
  19. Naman Bhalla
    ROMs through stock recovery and twrp are same.
  20. utkarshrajsingh
    Froyo Nov 6, 2015
    I have already tried factory reset. Is flashing worth a try?
    Should i wipe device completely?
