Fingerprint sensor and home button suddenly stopped working.
  1. Naman Bhalla
    Recognized developer Recognized Developer Nov 6, 2015
    Naman Bhalla , Nov 6, 2015 :
    Yes.Flashing is worth a try.And yes,wipe completely.If that doesn't work,go for return. :)
    Tokolozi likes this.
  2. utkarshrajsingh
    Froyo Nov 6, 2015
    utkarshrajsingh , Nov 6, 2015 :
    Okay, i'll flash it, but i dont think i can return my device. Its more than month old now.
  3. Naman Bhalla
    You can . :)
  4. utkarshrajsingh
    Froyo Nov 6, 2015
  5. rajeshmishraopx
    Cupcake Nov 6, 2015
    rajeshmishraopx , Nov 6, 2015 :
    i have same probs with op2
  6. Naman Bhalla
    Oh...If you are from India,then you can't . Sorry.
  7. utkarshrajsingh
    Froyo Nov 6, 2015
  8. batranikhil
    Cupcake Nov 6, 2015
    batranikhil , Nov 6, 2015 :
    Well - It has worked for some people - they have also mentioned letting your battery drain out completely. Not sure how that helps, but can try.
    I will try flashing later today - will let you know if it works - not very hopeful though - looks like a Hardware issue. Fingers Crossed..
    Cheers,
    Nik
  9. utkarshrajsingh
    Froyo Nov 6, 2015
    UPDATE :
    The hardware button is now responding to 50% of my touches (I did a full reflash with ak kernel, but the problems stills persists), but the fingerprint sensor is still completely unresponsive.
    Also, there are now a lot of ghost touches when i switch to hardware button. I'm guessing there's something wrong with the internals due to a fall or something.
    I'll be taking it to the service center tomorrow.
    I'll keep you guys updated.
    Bu as far as i am concerned, there's an issue with the hardware.
  10. ciclo00
    Cupcake Nov 14, 2015
    ciclo00 , Nov 14, 2015 :
    Mine home button and fingerprint scanner wont work aswell
    tried everything.
  11. nazimsaleem
    nazimsaleem , Nov 14, 2015 :
    hi man, im too facing the same issue from the very first week i had the finger print/home button issue but after draining the battery fully and then charged it . it worked but from last week onwards the same issue has started. tried flashing and clearing cache but it doesnt work. any solution . i bougt the op2 two months back
  12. Ksreddy9
    Honeycomb Nov 14, 2015
    Ksreddy9 , Nov 14, 2015 :
  13. sudnut
    Ice Cream Sandwich Nov 14, 2015
  14. Karthik287
    Cupcake Nov 16, 2015
    Karthik287 , Nov 16, 2015 :
    How
    How did they respond at the service center? Mine is barely a month old and my fingerprint sensor isnt working. One service center I went to wasnt open but a guy who works there told me its a standard problem that is covered under warranty. Any idea how long they take for warranty claims?
