sethupathiraja , via OnePlus 8 , Sep 26, 2020 : I had applied screen protector the UV tempered glass on my oneplus 8 now fingerprint is not working [e]1f623[/e]
Adzkii , via OnePlus 8 Pro , Sep 26, 2020 : is it the glue version of the tempered glass? cos if it is then they don't work well with curved screens
Manveet , via OnePlus 7T Pro , Sep 27, 2020 : I did not have this problem on 7T pro after applying uv tempered glass. Probably the quality of the screen protector is not good. Not all screen protectors behave well with fingerprint scanner. So you have to be careful before buying.
Cheezburgers , Sep 27, 2020 : could be poor quality protector you can try to re register your fingerprints
Mandadi siddhartha reddy , via OnePlus 8 Pro , Nov 18, 2020 : I tried that too, for my OnePlus 8 Pro ! Even though it's not working broh..
Frostywuff , via OnePlus 8 , Nov 18, 2020 : Just applied a new uv screen protector and it works fine without having to register again
Frostywuff , via OnePlus 8 , Nov 18, 2020 : What county are you from? Cos It is from a local company here, I bought it online.
Frostywuff , via OnePlus 8 , Nov 18, 2020 : Don't think they ship there, sorry. But you can check out sites like ********** there are plenty
KluGe , Feb 10, 2021 : If you use "search" in the forum you will find the answer. No need to pollute the forum with a new thread to a known issue.
Shyam11421 , via OnePlus 7 , Jan 21, 2022 : I recently applied uv glass for my OnePlus 7 fingerprint is not working can someone tell me which uv temper glass suits better
