Fingerprint sensor issue 3.0.2
Do you face any issues with fingerprint scanner post 3.0.2 update
  1. Yes
    54.2%
  2. Absolutely Not
    45.8%
  1. hrushis
    Froyo Jun 8, 2016
  2. Nikkz
    Froyo Jun 8, 2016
  3. d1beats
    Jelly Bean Jun 8, 2016
  4. marinobiagio
    KitKat Jun 8, 2016
  5. 1960
    Honeycomb Jun 8, 2016
    1960 , Jun 8, 2016 :
    Mine is Working like charm
    If you updated from lollipop then you MUST delete & re-register all your fingers...
    It will work fine
  6. Vonperz
    Donut Jun 8, 2016
    Vonperz , Jun 8, 2016 :
    Hello! My tip that work twice....
    1. Drain the battery
    2. Let the device lay drained about 48 hours
    3. Charge the battery to 100 % without turning it on
    4. Turn it on and the finger print reader /home button works again
    My first malfunction either finger print reader or home button worked
    The second time the finger print reader didn't work....
    Good luck!!
  7. hrushis
    Froyo Jun 9, 2016
    hrushis , Jun 9, 2016 :
    How many know what is clean flash
  8. hrushis
    Froyo Jun 9, 2016
    Any logic for 48 hrs
  9. ariel.us
    Froyo Jun 9, 2016
    ariel.us , Jun 9, 2016 :
    I contacted support yesterday for a home button / fingerprint issue, they suggested a reset to factory, so before doing that, checked for updates, seen OOS302, installed it, got my home button back, but no fingerprint
    Today I removed my tempered glass protection because it was chipped, and then fingerprint started to work.
    Coincidence or new image? not sure..
  10. MikeHoward
    Eclair Jun 9, 2016
    MikeHoward , Jun 9, 2016 :
    FP scanner isn't working for me after updating to OOS302. I tried setting up my FPs again and now the scanner won't even recognise when I'm pressing my finger down on it; meaning I'm unable to set up a new FP.
    This was working fine this morning before I updated.
    kobleznbitz likes this.
  11. Nopanand
    Froyo Jun 9, 2016
  12. kencck05
    Cupcake Jun 9, 2016
    kencck05 , Jun 9, 2016 :
    i have same problem...
    debonotimothy likes this.
  13. oneplusadi
    Donut Jun 9, 2016
    oneplusadi , Jun 9, 2016 :
    My FP scan doesnt unlock the device. It just wakes it up. I still need to unlock it using pattern code. Is any one else facing this issue?
    kencck05 likes this.
  14. pgalatage
    Cupcake Jun 9, 2016
    pgalatage , Jun 9, 2016 :
    not working for me home button unresponsive and fingerprint is also not working.
    Please let me know how to clean flash.
  15. pgalatage
    Cupcake Jun 10, 2016
    pgalatage , Jun 10, 2016 :
    Thanks man, it worked for me.
    only one change in step 2. you dont need to keep phone off for 48 hours. after 0% try powering on phone for around 25 times so it goes dry completely in 15 minutes. then 100% full charge without removing cable tried your steps worked thanks man.
  16. pgalatage
    voperz solution worked for me.
    2. try switching phone on around 25 times in 15 minutes continuosly. at a time it will not give you start logo as well.
    3. then Charge the battery to 100 % without turning it on
    4. Turn it on (without removing cable) and the finger print reader /home button works again
  17. Antonio.Loera96
    Gingerbread Jun 10, 2016
  18. Sciaracastro
    Sciaracastro , Jun 10, 2016 :
    It first showed the "Fingerprint hardware not available" when I passed my finger on the Home button (so I guess it was working) and now it stopped working completely.
    I've been a pretty satisfied user for months and this was a complete disappointment.
    I tried the *#808# in the dialer and both tests failed.
    I wanna cry.
  19. thewrench80
    thewrench80 , Jun 10, 2016 :
    when i do the *808 the first test , test of the sensor is ok, the 2nd checkboard test comes back failed everytime?
    what is that test doing? might help to figure out why the home button works as a home button but the finger print sensor is not working, keep getting hardware unavailable? what is it doing? sleeping?
  20. thewrench80
