[Submitted] Fingerprint sensor not working after 11.0.8.12 update
  1. RonakPawar15
    Cupcake Apr 5, 2021
    RonakPawar15 , Apr 5, 2021 :
    Hi I'm using one plus 8t.My fingerprint sensor stopped working after 11.0.8.12 update i have to reboot or power off the device to make it work which usually last for 5 min then it again stops
    Plz find me a solution
  2. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Apr 6, 2021
    Suhas Klkrn555 , Apr 6, 2021 :
    We'll definitely work on the issue reported and we'll do our best to help you. We've got in touch with you via direct message. Looking forward for your response!
    Thanks & Regards,
    Suhas.
  3. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Apr 8, 2021
    Suhas Klkrn555 , Apr 8, 2021 :
    Thanks for taking time to share the required information and we’ll keep you posted regarding the further updates.
    Thanks & Regards,
    Suhas.
