fingerprint sensor
  1. G_Yogesh_Solanki_sfjx
    Eclair Jan 12, 2018
  2. MJ_Vikram
    KitKat Jan 12, 2018
  3. Parag_Mallick
    Cupcake Jan 12, 2018
  4. idkwhoiam322
    Nougat Jan 12, 2018
    idkwhoiam322 , Jan 12, 2018 :
    If you're on Oreo, that is now linked to the "vibrate on tap" as mentioned above. It is NOT a bug!
  5. Its.Leandroo
    The Lab - OnePlus 6 Reviewer Jan 12, 2018
    Its.Leandroo , Jan 12, 2018 :
    You probably have "vibrate on tap" turned off.
    Check your settings > sound & vibration > vibrate on tap > on
    BHAUMIK.T007 likes this.
  6. BHAUMIK.T007
    Eclair Jan 12, 2018
    BHAUMIK.T007 , Jan 12, 2018 :
    but this setting makes vibrate every single touch of any three button.
    i want only 1 vibrate when my phone unlocks via fingerprint sensor.
    thnks btw
  7. Its.Leandroo
    The fingerprint sensor only vibrates when unlocking failed.
    There is no way to change this behavior
  8. BHAUMIK.T007
    Eclair Jan 12, 2018
    ya i know
    they removes this...in the update of oreo.
  9. santhosh311983
    Honeycomb Jan 12, 2018
  10. Its.Leandroo
    Yep. This was done because people complained about the fact that you couldn't turn fingerprint vibration off.
    So the next step is independent settings for the sensor and navigation buttons
