3
Fingerprint unlock via OnePlus 8T
  1. kvladan
    Gingerbread Mar 2, 2021
    kvladan , via OnePlus 8T , Mar 2, 2021 :
    Hello, every morning when I wake up and after not using the phone 7-8 hours fingerprint unlock can't unlock every time. Unlocks from every third attempt.
    After ten or fifteen successful or unsuccessful attemps fingerprint unlock begin to function normally.
    I have allready deleted and uploaded a new fingerprint three times, but again this difficult unlocking happensevery morning.
    Let me mention that I don't use protective screen glass, there is a factory foil on the sreen.
    I ask how the fingerprint unlock will work when I put one the protective glass???
    I am currently on Oxygen OS 11.0.7.10.KB05BA.
    Before I buying OnePlus 8T I used OnePlus 6T and I no had problems with fingerprint unlock.It worked much better on the OP 6T.
    Does anyone know what the problem is.
    Thank you.
    .Api, Hippie34 and Dj Hairless like this.
  2. ShreyasPatil_
    Jelly Bean Mar 2, 2021
    G1598956327076 and kvladan like this.
  3. X1603141720046
    Honeycomb Mar 2, 2021
    X1603141720046 , Mar 2, 2021 :
    I find in my case that upon unlocking the phone I have a similar issue. However, if I wait about one or two seconds, and then place my finger/thumb squarely and slightly firmly upon the reader it works. After unlocking the reader works without issue. So to me it appears as if the reader is going into a deep sleep and needs a second or two to "wake up" as it were. It has improved a little over time with various updates but there is still an issue.
    kvladan likes this.
  4. kvladan
    My finger is clear and I haven't screen protector.
    This is the problem
  5. Dj Hairless
    Eclair Mar 2, 2021
    Dj Hairless , Mar 2, 2021 :
    Same thing here! I thought it was only me with this problem. When I woke up and want to unlock my phone, finger print scanner not lighting up so i must put my code to unlock phone, then finger print scanner working fine again.
    kvladan likes this.
  6. kvladan
    OnePlus must to resolve this issue....I hope!?
  7. vikarshaikh18
  8. W1601154258210
    Cupcake Mar 2, 2021
  9. kvladan
  10. kvladan
    I know that...but nothing...I used OnePlus 6T for two years....fingerprint unlock works perfect
  11. kvladan
    OnePlus 8T is my 4. phone with fingerprint unlock....I know what to do.....no screen protector, everything clear....big issue with my device
  12. X1603141720046
    Honeycomb Mar 3, 2021
    X1603141720046 , Mar 3, 2021 :
    I'm not sure they can fix anything more with software. I think there's something wrong with the reader itself. Fortunately I can live with it for now.
    kvladan likes this.
  13. Goggeboy
    Honeycomb Mar 15, 2021
    Goggeboy , Mar 15, 2021 :
    I think also, that it's a hardware problem. I'm having same problems with 8T
    With 7T and 6T no problems and with OP6 same problems.
    Or is it Android 11?
    Even when trying to make new fingerprints it's usually fails.
    kvladan likes this.
  14. AntonisPapas
    Froyo Mar 15, 2021
    kvladan likes this.
  15. #15
  16. Hippie34
    Froyo Mar 16, 2021
    Hippie34 , Mar 16, 2021 :
    I had same problem had to redo my fingerprint but sometimes just restarting works
  17. DGarnes
    Cupcake Mar 16, 2021
  18. DIVITH.C
    Ice Cream Sandwich Mar 16, 2021
  19. kvladan
    Gingerbread Mar 16, 2021
    kvladan , via OnePlus 8T , Mar 16, 2021 :
    I haven't screen protector, only foil on my new device.
  20. MuraliKrishnan22 , via OnePlus 8T Lunar Silver , Mar 17, 2021 :
    I guess you are moving your fingers too quickly while unlocking your phone...
    That's us the reason for too many unsuccessful attempts.
    Place ur fingers on scanner and wait for your phone to unlock it should unlock with in 1 sec..
