First Impressions OF the One Plus 2
  1. kunalkankariya
    Gingerbread Aug 18, 2015
    kunalkankariya , Aug 18, 2015 :
    So it is a software issue & not a issue with the sensor as such?
    I never said I am not comfortable with it, merely responding to a suggestion made by a user here. If it was a hardware issue, I wouldve got it replaced. Glad to know that its not :)
    Are you facing any other issues with your OP2?
    #41
  2. Subhasis.M
    Ice Cream Sandwich Aug 18, 2015
    Subhasis.M , Aug 18, 2015 :
    FP and another issue related to WiFi to Mobile Data switching.
    The phone switches to Mobile Data every now and then even if its connected to a strong WiFi network.
    End up getting pop-up messages for the data switch, which is annoying.
    Some app crashing (stay away from dark theme for now). Nothing beyond this.
    #42
  3. sandeep_khopade
    sandeep_khopade , Aug 18, 2015 :
    Along with your hands you should have washed OPT as well. :p JK
    #43
  4. raghupro
    Honeycomb Aug 18, 2015
    raghupro , Aug 18, 2015 :
    The fingerprint issue is because of the thin layer of oil that keeps building up when you put the phone against your face to take calls. Clean the sensor with a soft cloth and it's good to go.
    #44
  5. raghupro
    Any issues with WiFi and mobile data switch over at times?
    Any issues with warm/yellow tint on bottom right side of the screen. Open a complete white image on the phone and check. Do you see the top part of the screen to be whiter than the bottom right?
    #45
  6. drjaga2004
    #46
  7. bhaskar.duvvuri
    bhaskar.duvvuri , Aug 18, 2015 :
    It's on the backside, more at the top.
    #47
  8. saivarun12
    saivarun12 , Aug 18, 2015 :
    how about the network signal coverage...? is it able to catch signal in low network area?
    #48
  9. vishnu.nanda
    Cupcake Aug 18, 2015
    #49
  10. Varun Chico
    Varun Chico , Aug 18, 2015 :
    hey thanks alot for the quick and pretty detailed response :)
    #50
    mukul chopra likes this.
  11. Varun Chico
    t
    Thanks Mate :)
    #51
  12. Varun Chico
    Id love to see more new users of the One Plus 2 post their user experiences on this thread.... and also notify us if you come across any bugs or defects.
    Thanks in Advance :)
    #52
  13. kufri
    kufri , Aug 18, 2015 :
    Hey Guys, just received my OP2 today, sort of
    mixed feelings coming from OPO. I like the foam factor & the feel, definitely premium. Got the Rosewood swap case & it looks all classy. The Oxygen OS is buttery smooth but coming from Cyanogenmod there are certain features you miss. Still just 6 hours with the beast hence can not add much to the user experience.
    However a few queries to other OP2 users:-
    1) The display looks on the warmer side, when i kept it beside the OPO, the OPO looked much brighter, surprising because OP2 has a better so called display then OPO, am i missing some settings here.
    2) Cannot add more toggles to the notification drawer which was available in CM12.
    3) Can not seem to find how to change the lock screen wallpaper.
    Edit
    4) Gujarati fonts not showing, this is surprising as the Lolipop update solved it on the OPO.
    Thanks & Cheers.
    #53
  14. Nidhin Raj
    KitKat Aug 18, 2015
    Nidhin Raj , Aug 18, 2015 :
    I'll probably get mine (well actually it's for a relative) tomorrow, bought only the flip back as accessory,
    #54
    shabeer meeran and kufri like this.
  15. vinod1223
    Froyo Aug 18, 2015
    #55
  16. 111.saahil
    Froyo Aug 18, 2015
    111.saahil , Aug 18, 2015 :
    I already bought the kevlar Back cover and Temepered Glass
    Still waiting for the invite
    One Nation, One Vision & One Identity"No Nation is Perfect,It Needs to be made Perfect"Meri Pehchaan Mera India
    @@FreeInviteCode @OnePlus_IN
    #56
    aryavarun and shantam31 like this.
  17. kanagadeepan
    KitKat Aug 19, 2015
    kanagadeepan , Aug 19, 2015 :
    Congrats @kufri ji..
    Can you test one thing in OP2?
    In OPO the voice clarity will be very bad (on receiver's end) in 2G mode, when call recorder is ON.. Can you try making voice call in OP2 on 2G mode with call recorder ON and check the voice clarity on other end??
    I have to have Call recorder running always and that is the reason I sold my OPO for cheap...
    #57
    kufri likes this.
  18. kanagadeepan
    KitKat Aug 19, 2015
    Congrats @mukul chopra Can you test one more thing in OP2?
    Thanks in advance....
    #58
  19. raghupro
    Honeycomb Aug 19, 2015
    raghupro , Aug 19, 2015 :
    Congrats on your new device!
    1. Yes, there is some issue with the display, the right bottom side will have more warmer colors in comparison and that's being observed by many users including myself.
    2. Yup, I couldn't manage it either. A few provided already that can be turned on or off.
    3. No clue, haven't tried it myself!
    #59
    kufri likes this.
  20. imTSS
    KitKat Aug 19, 2015
    imTSS , Aug 19, 2015 :
    Congrats. For ur first query... Put both devices in full manual brightness and compare. About ur other queries I have no clue...
    #60
    kufri likes this.
