First Problem with OPO
  1. addam
    KitKat Jan 9, 2015
    addam , Jan 9, 2015 :
    They also said that I dosnt matter if the phone is on or off
  2. rpowel2
    Gingerbread Jan 9, 2015
    rpowel2 , Jan 9, 2015 :
    The OPO doesn't "need" Root, just as any other android need it. But to truly enjoy the capabilities root is a pleasure
  3. Geigeorge
    Cupcake Jan 9, 2015
    Geigeorge , Jan 9, 2015 :
    download advanced battery calibrator; charge phone to 100%, then run the app, press button on app, restart OPO, and you are up and running. What I did read is that it's important most of the time to use the original OPO charger as maybe it contains other Amps then other chargers. true or not, this sol worked for me. No need to root the phone by the way..
    dreniacdre and 335761656 like this.
  4. 335761656
    Froyo Jan 9, 2015
  5. pravins146
    Donut Jan 9, 2015
    pravins146 , Jan 9, 2015 :
    I too am facing the problem of charging the phone which is currently at 40%.. it refuses to charge using the original OPO charger when connected to a power socket. Had charged it to full 100% the previous day.
    However, when OPO charger was connected it to my PC the battery charging status was up. Phone was also able to charge with other Charger but not with the OPO charger.
    Can anyone let me know the reason why the phone doesn't charge with OPO charger?
  6. joan56
    joan56 , Jan 9, 2015 :
    Thanks to all for the suggestions, I'll be sure to get back with the end results
    addam likes this.
  7. Geigeorge
    Cupcake Jan 9, 2015
    could be a defective charger. does any other charger (e.g. any USB will do) have the same symptoms?
  8. eva680
    Eclair Jan 9, 2015
    eva680 , Jan 9, 2015 :
    Do u mean once u have that issue, u will solve the problem by those steps?
    addam likes this.
  9. pravins146
    Donut Jan 9, 2015
    Right now I'm using Moto G charger to charge my OPO and it is charging fine.
  10. addam
    KitKat Jan 9, 2015
    To be honest I'm not sure, I am currently talking to OnePlus about my random reboot issues. They have given me a few steps to try in an attempt to solve my problem. This is one of the steps. It didn't solve my reboot issue but I figured I could pass on the information and maybe help someone else out.
  11. hunjak
    Cupcake Jan 9, 2015
    hunjak , Jan 9, 2015 :
    Symptoms say: a failed battery's characteristics is something you describe, drops voltage earlier - e.g. when your phone thinks there is still 30% juice available - and this dip forces your phone to shut down or turn off. Your battery should also be distorted - but it's hidden behind the back cover...
    There is a small chance that the battery is not properly charged and the charging circuit is weak to recognize the problem (don't start flaming fanboys, almost all devices use the same creepy boards).
    The best would be to charge the battery 100% outside of the phone with the proper lipo charger - but as it's not replaceable, your only option is to follow addam's steps...
    These type of battery calibrators do nothing but remove the battery statistics file - with battery usage statistics, including information on wakelocks, processes, packages, and services - used to persists information between reboots. This has no effect on charging!
    R, KJ.
    Chottobaka and encrypted11 like this.
  12. Geigeorge
    Cupcake Jan 9, 2015
    Well it solved my problem, now phone starts from 100% and shuts at 1% as it should..it is worth a try since it's the easiest.
  13. encrypted11
    Froyo Jan 9, 2015
  14. encrypted11
    Froyo Jan 9, 2015
    encrypted11 , Jan 9, 2015 :
    That wa
    That was debunked by Google for a long time.. It does nothing.
  15. Toulouse
    KitKat Jan 9, 2015
  16. encrypted11
    Froyo Jan 9, 2015
    Toulouse likes this.
  17. Cooperman
    Cooperman , Jan 9, 2015 :
    So not good for a phone with a non-replaceable battery!:mad:
  18. Kochens
    Honeycomb Jan 9, 2015
    Kochens , Jan 9, 2015 :
    You are totally wrong, because the % indicator are not right, if the battery neds calibration!
    #38
  19. hunjak
    Cupcake Jan 9, 2015
    Thats not that easy.
    First: the 500 cycle is a very good value!
    Second: if a battery has 500 cycles for 100% DOD (depth of discharge, 100% means fully discharged), the battery would do some 1500 cycles with 50% DOD!
    yes, as always... Having my old phone handed over to family member after 1.5year all I had to do is to buy a new battery and replace it myself.
    R, KJ.
    #39
  20. hunjak
    Cupcake Jan 9, 2015
    correct. 100% displayed on your android screen is not always 100% in your battery.
    The problem is that the integrated charge circuits are not programmable, you can't always calibrate your battery with those boards - that's why it would be recommended to do a real battery 100% calibration with an external/professional charger/calibrator.
    TI: try to cool down your device/battery after charging it to 100% and then continue charging for some more time.
    R, KJ.
    #40
