651
Fix all performance and battery drain issues with this Guide!
  1. JoshuvaAntony
    Ice Cream Sandwich Jan 22, 2017
    JoshuvaAntony , Jan 22, 2017 :
    *UPDATED (19 - Jan - 19)* : New Guide which is More Easier and Effective!
    # Guide for Oneplus 6t / Oneplus 6 / Oneplus 5t / Oneplus 5 / Oneplus 3T / Oneplus 3 running Android Oreo/Pie #
    [All the steps mentioned in this guide are safe to use and wont affect any apps or data]
    Step 1 : Go to settings - scroll down - click about phone - scroll down again - click build number 4 or 5 times until it says "You are now a developer"
    Step 2 : Go back - In settings you can see a new option named as Developer Options - click and enable it. There are many things there...dont worry! Disable Doze Mode and enable Advanced reboot only. Dont do anything else!
    Step 3 : Go to settings again - battery - look into the top right corner, you can see 3 dots - click it and select aggressive doze and app hibernation or known as Advanced optimization inside Battery Optimization
    It is enabled there. Disable it. (Its important that you disable this)
    Step 4 : Go to settings - Storage and Memory - Storage - Click Cached Data - Press ok.
    Step 5 : Go to settings - Apps - select Google Play Services among the list - click storage - manage space - clear data. After that dont press back or home key.
    Step 6 : Press and hold the power button - select reboot - You can see three options now! that is - Reboot , Recovery , Bootloader. Press Recovery and your phone will automatically boot in recovery mode. ( No need to do tiresome press , hold and all ).
    Step 7 : When in recovery mode - Select English - Wipe Data & Cache - click Wipe Cache option - Press ok - Then you get two options - Reboot , Done - Jst press Reboot and your phone will boot up normally.
    Wait for sometime..min 2 mins after showing lockscreen. Jst dont do anything like unlocking it or anything.
    (Note : Make sure Agressive Doze & App Hibernation in Battery settings and Advanced boot in developer settings are disabled after following all steps.Then, Enable Doze Mode in developer settings)
    {{ !!!Warning!!! : Pls dont use any apps which wants accessibility service to work. Pls go to settings - Advanced - Accessibility - Pls turn off all apps under Services Tab. Because it can cause huge smoothness bug for the Android Os. People who have enabled accessibility service for apps are experiencing lag issues on the phone especially when sliding the notification bar. Most commonly used app named "Greenify' uses this accessibility service. So pls turn the service off and uninstall the app }}
    Pls share your Experience in the comments section,
    For any problems and doubts related to Software or Hardware. Follow me and send a message on Instagram (joshuva_antonio).
    From Today, I will be actively available for all of your Tech needs.
    Enjoy Lads!
    "Never Settle"
    By, Joshuva Antony
  2. JoshuvaAntony
  3. jansvanda
    Honeycomb Jan 22, 2017
  4. JoshuvaAntony
    Yes! The steps may sound stupid...bt pls try it out and tell me your opinion. Am trying to help :)
  5. WartleS
    Gingerbread Jan 22, 2017
    WartleS , Jan 22, 2017 :
    I'm using these methods and I can confirm it works. But for the step 1 and 2, I use SD Maid.
  6. JoshuvaAntony
    Thank you for your support! Pls spread the word.
    Avast cleanup is lot more easier for all people comparing sd Maid. Thats why i recommend Avast cleanup. Most of the cleaning apps available are jst useless and even makes phone slower.
  7. JoshuvaAntony
    After following these steps...pls dont forget to post your experience in this thread. Be helpful and spread the word.
    Bye the way sorry for the minor spelling omissions :)
  8. gecharo
    Froyo Jan 22, 2017
  9. F_William_Guttman_JhRM
  10. JoshuvaAntony
    Ice Cream Sandwich Jan 23, 2017
    JoshuvaAntony , Jan 23, 2017 :
    Waiting for your happy report.
    amitssj likes this.
  11. amitssj
    Honeycomb Jan 23, 2017
    amitssj , Jan 23, 2017 :
    I was also getting battery drain on my oneplus 3T after updating to Nougat but clearing out cache and enabling Doze mode in developer options... i am getting more than 7+ hours of SOT. even i am connected to Wifi at all time... Thanks
  12. G_Joshua_Rodriguez_ohoo
    Froyo Jan 23, 2017
    JoshuvaAntony likes this.
  13. Sushma_Bhardwaj
    Cupcake Jan 23, 2017
  14. JoshuvaAntony
    I had also heard that normal doze is better than aggressive doze. Will check it in a few days.
    Thank you for reaching out. Have a great day.
    Dylan6793 and amitssj like this.
  15. Zh_kilat
    Android Q Jan 23, 2017
    Zh_kilat , Jan 23, 2017 :
    You may try this trick, if factory reset really bothers you
  16. Ceasedd
    Marshmallow Jan 23, 2017
    Ceasedd , Jan 23, 2017 :
    Avast it's kinda good but no thanks.
  17. manimaarans
    G_Pulak_Mishra_ZMAE likes this.
  18. G_A_Mannan_ZKEa
    Froyo Jan 23, 2017
  19. SushanthMJoseph
  20. uBreaky
    Gingerbread Jan 23, 2017
    uBreaky , Jan 23, 2017 :
    i wiped cache without step with Avast cleanup 2 day ago
    I need to retry with Avast ?
    I'm not sure if my battery lire is optimized but it's better than first day :')
