650
Fix all performance and battery drain issues with this Guide!
  1. jimjimjimjim
    Cupcake Jan 28, 2017
    jimjimjimjim , Jan 28, 2017 :
    Confirmed working, follow the guide thorougly!
    Before I hade no time with "phone inactice" in battery statistics. After, I have almost all time inactive overnight.
  2. bikkad
    Donut Jan 28, 2017
    bikkad , Jan 28, 2017 :
    I am currently on Naugat and my battery performance is very bad. After charging to 100%, If I working on Wi Fi, it lasts only for 4-5 hours. Is it normal?
  3. Alp123
    Froyo Jan 28, 2017
  4. Alp123
    Froyo Jan 28, 2017
  5. G_manish_amarnani_zgid
    Gingerbread Jan 28, 2017
  6. G_manish_amarnani_zgid
  7. klayman
    klayman , Jan 28, 2017 :
    Battery drain and lots of other bugs there are in Nougat. But who does not found one until now it will. My OP3t last bug less"" 4 day and I was happy with it, installed 4.0.2 clean with all resset after.
    Biggest bug is that for no reason the phone start to heat up in my pocket. Found that Google services was the cause and nr 1 battery drain app. Do not no why. On 4.0.2 there is some kind of lag in UI. (I am experienced user, done all resset, format)
    I downgraded to 3.5.4 and my phone flyes again. No more lag no more battery drain. Absolutely fantastic!
    So do not go for Nougat until next release
  8. masaichris
    Donut Jan 28, 2017
  9. JoshuvaAntony
    Ice Cream Sandwich Jan 28, 2017
    JoshuvaAntony , Jan 28, 2017 :
    Yep. Same as mine! Sometimes only 1% though. Thank you for the reply.
    niyu26 likes this.
  10. JoshuvaAntony
    Yes you are absolutely right. Even if there are other reasons. Google Play services is the real culprit here.
  11. JoshuvaAntony
    Glad to hear that Jim! Do share your experiences with this thread.
  12. JoshuvaAntony
    Its up to you. Bt normal clean is jst enough.
  13. JoshuvaAntony
    Try this fix...it might work or not. The steps are safe so you dont need to worry. If you can have a 5mins off try it...wont affect your files or apps.
  14. chirag nayak
    Donut Jan 28, 2017
  15. SachinTS
    Honeycomb Jan 28, 2017
    SachinTS , Jan 28, 2017 :
    tried let's wait
  16. IrfanO
    Eclair Jan 28, 2017
    IrfanO , Jan 28, 2017 :
    android system and Google play services causing battery drain on 4.0.2. hope they fix this. getting sot of around 5hrs before easily 6
  17. manou63
    Eclair Jan 28, 2017
  18. kistedu
    Eclair Jan 28, 2017
  19. navinf
    Eclair Jan 28, 2017
    navinf , Jan 28, 2017 :
    clearing cache data will clear all the ongoing app data right? That means all the saved stuff on particular apps?
  20. Cyberplan
    Donut Jan 28, 2017
