652
Fix all performance and battery drain issues with this Guide!
  1. LMcR92
    Gingerbread Jan 23, 2017
  2. G_Manjunath_dWzL
    Donut Jan 23, 2017
  3. Jaiminbm
    Honeycomb Jan 23, 2017
    anupdcruz and Vaibhav Taly like this.
  4. JoshuvaAntony
    Ice Cream Sandwich Jan 23, 2017
    JoshuvaAntony , Jan 23, 2017 :
    Yes...i do t recommend it for a use of lifetime. Its jst a one time running...as i mentioned you can uninstall it after step 2.
    G_Ron_Lessner_cNFF and Ceasedd like this.
  5. JoshuvaAntony
  6. JoshuvaAntony
    Yes it is...bt avast is more easy for common people..for my procedure avast is only needed and recommended by me..You can uninstall it after step 2.
    EgonMeijers likes this.
  7. Ceasedd
    Marshmallow Jan 23, 2017
    Ceasedd , Jan 23, 2017 :
    I see,I don't have those battery issues yet.I will keep it in mind nevertheless.
    Arachniac1 likes this.
  8. Henri243
    Eclair Jan 23, 2017
    Henri243 , Jan 23, 2017 :
    Will this cause data loss? I would do Factory reset but I really don't feel like installing all the apps (+120) again.
    Mhin.666, chinnidiwakar and perryfig like this.
  9. JoshuvaAntony
    You are always welcome.
    Thank you for showing back support!
  10. fahada
    Donut Jan 23, 2017
  11. JoshuvaAntony
    No my friend, your data will be safe if you follow my steps accordingly. Pls dont worry am here to help.
    Data wont be erased.
  12. JoshuvaAntony
    Yes may it be good news...!! Do share your experience in this thread. It can help a lot of people.
  13. JoshuvaAntony
    No problem ! You can go with these steps.
    G_Leonel_Castro_zwQX likes this.
  14. JoshuvaAntony
  15. Henri243
    Eclair Jan 23, 2017
    Okay great. Will try this now.
  16. JoshuvaAntony
    You can also refer youtube on how to wipe cache in recovery mode on oneplus 3/3t. Its easy ! jst follow my steps in order. When in recovery mode make sure you press the wipe cache options only! Jst as told in Step 5. Dont press factory reset or erase everything.
  17. Henri243
    Eclair Jan 23, 2017
    Yeah I followed your guide step by step. No problems at all. Now I'll have to wait and see If my battery life improves or not. I had decent battery life, no huge battery drain but the "Android os" and "Android system" were among the top3 most battery consuming services. Let's see if this fixes it.
  18. One_Plus_2_user.
    Cupcake Jan 23, 2017
    One_Plus_2_user. , Jan 23, 2017 :
    Dude!
    can this trick can be done with One Plus 2
    i have updated it to Oxygen OS 3.5.6
    The Performance is good just my battery drains very quick
    Your help would be appreciated [e]263a[/e]️
    #38
  19. Aswin Philip
    Aswin Philip , Jan 23, 2017 :
    Hi,
    I am having stuttering during scrolling and swiping. Event after following your steps it persists.
    #39
  20. Henri243
    Eclair Jan 23, 2017
    Do you have Avast antivir installed? I've read reports that it can cause issues that you just described
    #40
    ivan liu likes this.
