652
Fix all performance and battery drain issues with this Guide!
  1. mannulko
    Gingerbread Jan 23, 2017
    mannulko , Jan 23, 2017 :
    same for me
    #41
    ivan liu likes this.
  2. wenna
    Ice Cream Sandwich Jan 23, 2017
    wenna , Jan 23, 2017 :
    I would like to know what exactly it is Avast does to the system?
    #42
  3. JoshuvaAntony
    JoshuvaAntony , Jan 23, 2017 :
    Hmm... The nougat's agressive doze is not performing well...even for nexus 6p..they are turning it off.. Try this,
    Step 1 - Go to settings - battery - click the options at the top right and disable agressive doze.
    Step 2 - Go to developer options - enable doze.
    For newbies, Developer options will appear when you go to about phone and clicking build number 4-5 times. Then go back and you can see the developer options menu in settings.
    #43
  4. JoshuvaAntony
    Yes...you can try this method bcoz its safe for any oneplus devices. I can't guarantee you if it will work...but its worth a try. Your phone and data will be safe!
    #44
    SMNajmusSakif likes this.
  5. JoshuvaAntony
    This fix might work...bcoz agressive doze is somehow degrading the performance on many phones. It may be google's issue.
    #45
  6. JoshuvaAntony
    Thank you for your reply. Stay tuned!
    #46
  7. G_Jacob_Mitchell_lbeu
    Donut Jan 23, 2017
    G_Jacob_Mitchell_lbeu , Jan 23, 2017 :
    My battery went down 30% in a half hour this morning before school. I just tried this along with enabling doze mode, and it does seem to be lasting longer. However, it is still draining at a much faster rate than before the update.
    #47
  8. JoshuvaAntony
    Yes i can understand. Its a issue by the oneplus team. I can only minimize the problems..for some it gets fixed too. Let me give you some tips regarding the battery life .
    1. Dont discharge your battery empty always. Stop using after it goes down by 25%.
    2. Always charge your battery in switched off mode. Its a lot more safer for the battery.(Dont worry dash charging will always work even its switched off or not).
    3. Charge your battery straight to 100%. In the procedure you can see the dash charging logo. Even after reaching 100% do not unplug your battery. Wait for another 5 - 10 mins and you will get a white battery icon with a tick on center. Pls refer the image below
    These steps can decrease the problems of battery wear out..bcoz when switched on...the battery gets drained and charged at the same time..which is too bad for your battery.
    Thank you for showing your support.
    Pls stay tuned.
    #48
  9. jatinkalra07
    #49
  10. G_Jefry_Oquendo_rPbn
    Cupcake Jan 23, 2017
    #50
  11. G_Jefry_Oquendo_rPbn
    G_Jefry_Oquendo_rPbn , Jan 23, 2017 :
    appeared after almost 30mins. the approximation improved.btw also disabled backup and restore.. will monitor until tomorrow. ty.
    #51
  12. bryoniesimon
    Donut Jan 23, 2017
    #52
  13. Cryptomancer
    Eclair Jan 23, 2017
  14. saurabhparwal
    Froyo Jan 23, 2017
    saurabhparwal , Jan 23, 2017 :
    Hey I have OP3, I want to ask whether the bootloader should be unlocked or locked for good performance?
    #54
  15. Aswin Philip
    Aswin Philip , Jan 23, 2017 :
    I have done these steps too. But no progress. I also made a bug report. Waiting for their reply too.
    #55
  16. Aswin Philip
    No. I have no such antivirus or cleaning apps.
    #56
  17. anilsinglasnm
    #57
  18. G_Jefry_Oquendo_rPbn
    #58
  19. F_Diganta_Koner_WIXu
    Jelly Bean Jan 23, 2017
    F_Diganta_Koner_WIXu , Jan 23, 2017 :
    I word of caution do not install avast it will screw your system to the extent where you can't even make out what is happening. As of performance issues after upgrade always perform a factory reset removing the system as well as the dalvik cache
    #59
    Anshuwali and TheMindy2011 like this.
  20. williamturpin1
    #60
