652
Fix all performance and battery drain issues with this Guide!
  1. mannulko
    Gingerbread Jan 23, 2017
    mannulko , Jan 23, 2017 :
    I don't think 30% battery drain is possible in one hour under any condition
    #61
  2. danyboy1234
    Honeycomb Jan 23, 2017
    #62
  3. G_Ben_Smits_qGmK
    Eclair Jan 23, 2017
    G_Ben_Smits_qGmK , Jan 23, 2017 :
    Not at all
    #63
  4. G_Ben_Smits_qGmK
    Eclair Jan 23, 2017
    Try playing a GPS game like ingress with the max screen light, it should do the trick ;p
    #64
  5. G_Siddhant_Kumar_zJiB
    Cupcake Jan 23, 2017
    #65
  6. JoshuvaAntony
    Ice Cream Sandwich Jan 23, 2017
    JoshuvaAntony , Jan 23, 2017 :
    No you are good to go...it wont be downgraded and your data will be safe.
    #66
  7. Mackubex
    #67
  8. ThomasBaer
    Froyo Jan 23, 2017
    ThomasBaer , Jan 23, 2017 :
    Dalvik is not in use anymore since MM. Android 6 and up uses ART.
    #68
  9. simosina96
    Donut Jan 23, 2017
    simosina96 , Jan 23, 2017 :
    Does anyone know if there is an app or a setting that makes possibile to show a toggle for switching from 3g to 2g (and from 2g to 3g) on the notification bar? For exampe I've noticed that shazam allows to create the toggle in the notification bar.. I think It's a great thing to have a confort toggle for switching it and it could save some % of battery.
    #69
  10. hanjie93
    #70
    UKFX likes this.
  11. fahada
    Donut Jan 23, 2017
    fahada , Jan 23, 2017 :
    Hey Josh,
    The problem still persists ... Battery is draining like anything and the phone is getting heated
    #71
  12. gjwilson21
    gjwilson21 , Jan 23, 2017 :
    It works for me. I am seeing good difference in battery life after I followed the steps in the original post. Thanks Joshuvaantony.
    #72
    niyu26 likes this.
  13. leo8296
    leo8296 , Jan 23, 2017 :
    This fix worked for me! Thanks to the OP for coming up with this solution.
    #73
    niyu26 likes this.
  14. g_au
    Eclair Jan 23, 2017
    g_au , Jan 23, 2017 :
    Wiping cache partition from recovery after an update is good practice as it prevents you currents OS trying to access temp files from a previous version.
    Also CCleaner by Piriform is a good app, and just delete cached data in settings.
    This 'wait 3 minutes' stuff sounds like nonsense, and people saying that their battery life has greatly improved are most likely experiencing placebo.
    #74
  15. JoshuvaAntony
    Thank you so much for the support. Glad to hear that your phone is ok. You may also disable Agressive doze because it hinders performance. Enable Doze from developer settings. And do a normal reboot.
    #75
  16. JoshuvaAntony
    You may also disable Agressive doze because it hinders performance. Enable Doze from developer settings. And do a normal reboot. I donno why.. by agressive doze is performing badly even in nexus devices like 6p.
    #76
  17. JoshuvaAntony
    Pls disable Agressive doze because it hinders performance . Pls enable Doze from develper settings and repeat these steps. Its really working great. I did it myself too! Too bad those steps didnt work for you. Pls try this and tell me how it goes.
    #77
  18. JoshuvaAntony
    I think you should post this on another thread as a feature request. Still yeah. The suggestion by you is a lot helpful if there is a feature like that.
    #78
  19. JoshuvaAntony
    Thank you for your support! Your reply helps other people a lot.
    #79
  20. F_Diganta_Koner_WIXu
    Jelly Bean Jan 24, 2017
    F_Diganta_Koner_WIXu , Jan 24, 2017 :
    Thanks for letting me know, was unaware of this fact
    #80
    ivan liu likes this.
