652
Fix all performance and battery drain issues with this Guide!
  1. Aman bajaj
    Eclair Apr 29, 2018
  2. shiv1g
    Honeycomb Apr 30, 2018
    shiv1g , Apr 30, 2018 :
    [e]1f44e[/e][e]1f44e[/e][e]1f44e[/e][e]1f44e[/e][e]1f44e[/e]
    NEVER WORKED.
  3. Bintang12
    Honeycomb May 1, 2018
  4. santhosh311983
    santhosh311983 , May 1, 2018 :
    Any comments on this..? I tried your steps. Still getting only 3.5 hrs SOT. BTW i used 4G for an hour.... And even OP customer support says using 4G drains battery.. Please suggest..
  5. santhosh311983
  6. santhosh311983
    But bro one question.. If you use mobile data.. Specially 4G.. I would say mixed usage..(like max 1 hour.. It's IPL season so you understand) What's the approx SOT you are achieving?
  7. santhosh311983
    Did you performed factory reset? If YES..then what about those Apps which you installed prior to the Factory Reset.. If all the apps were intact?
  8. leeperks86
    Froyo May 21, 2018
  9. F1526933683376
    Cupcake May 21, 2018
  10. santhosh311983
    Honeycomb May 22, 2018
    santhosh311983 , May 22, 2018 :
    did you charge your phone in between ? and your SOT is stellar ..so still u getting same SOT even after multiple charge cycles ?
    AntonioBongco likes this.
  11. AntonioBongco
    Eclair May 22, 2018
  12. AntonioBongco
    Eclair May 22, 2018
    AntonioBongco , May 22, 2018 :
    here's mine today. left the house 6am for work, never charged my phone, mostly on 3G, got home at 5pm still at 38%
    at 7pm 18% I have achieved 3.15 hours SOT
    I'm rooted with ElementalX, AKT Xana Extreme batt, Disable Serv app, Greenify but connected to a Samsung Gear S2 via BT
    is this a decent SOT already or can I push for more but not sacrificing the BT wearable?
    Cheers!
  13. theunforgivenme2
    Cupcake May 22, 2018
    theunforgivenme2 , May 22, 2018 :
    The developer options in settings is still active , can I disabled it ? I just finished doing all steps mentioned and don't see any change as of yet
  14. kzlimon
    Cupcake Feb 20, 2019
  15. anupritaisno1
    KitKat Feb 20, 2019
    Bintang12 and kzlimon like this.
  16. PTuT
    Jelly Bean Feb 20, 2019
    PTuT , Feb 20, 2019 :
    Because saying it will fix ALL performance/battery related problems is a little bit of overstretch. Try to boot in safe mode and observe. Should at least let you know if some app is misbehaving.
    Bintang12 likes this.
  17. N1546358644500
    Cupcake Feb 21, 2019
  18. N1550803111121
    Cupcake Feb 22, 2019
    N1550803111121 , Feb 22, 2019 :
    Thanks a Lot
    My Mob was continuously getting switched off, I did many things deleted softwares, antivirus, system reset, nothing worked, but your guidelines worked perfectly
    Thanks a Lot
    Regards
    Mayur Nahar
  19. anupritaisno1
    KitKat Feb 22, 2019
  20. anupritaisno1
    KitKat Feb 22, 2019
    anupritaisno1 , Feb 22, 2019 :
    Give this a read
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    revonomics likes this.
