3
fix android auto
  1. Stefke1974
    Froyo Jul 14, 2018
    strakszys, risafov and Hikari691 like this.
  2. Shawnlane
    Froyo Jul 14, 2018
    Shawnlane , Jul 14, 2018 :
    I am using the OnePlus 6 in my car. I own a 2017 GMC Acadia and Android Auto works fine it in. Did you try deleting Android Auto app from your phone and downloading it again?
  3. Stefke1974
    Froyo Jul 14, 2018
    Stefke1974 , Jul 14, 2018 :
    yes ofcourse
    buy seems that not all OP6 are having this issue
    when you do a search, you find several threads about this issue
    seems to be a issue with notch
  4. Stefke1974
    Froyo Jul 14, 2018
    im using it in smart forfour 2018 with Smart Media System
    my old Huawei does not have a issue
    only the OP6
    or maybe im using wrong version of Android Auto?
    what version are you using? arm version?
  5. Shawnlane
    Froyo Jul 14, 2018
    This is the version I am using.
    Android Auto: 3.4.582534-release
  6. pyroxide
    Cupcake Jul 14, 2018
    pyroxide , Jul 14, 2018 :
    I just installed a Pioneer AVH-W4400NEX and I initially was unable to get wired Android auto connection to work. I narrowed it down to the USB extension cable that was provided with the radio. Hope this helps.
  7. G_Karel_Straka_OnQM
    Donut Jul 15, 2018
  8. mclovin5799
    Gingerbread Jul 15, 2018
    mclovin5799 , Jul 15, 2018 :
    since when is Android auto supported in The Netherlands?? last time I checked it wasn't supported in The Netherlands (2months ago)
  9. Stefke1974
    Froyo Jul 15, 2018
    Stefke1974 , Jul 15, 2018 :
    it is not officialy but you can simply download the apk file
    same for belgium
  10. mclovin5799
    that didn't even work for me, can you share a link?
  11. Stefke1974
    Froyo Jul 15, 2018
    sure
    first download droid info to check correct version that you need
    in my case "arm64-v8a"
    then go to:
    https://www.apkmirror.com/apk/google-inc/android-auto/android-auto-3-3-5820-release/#downloads
    download apk directly to you device (not computer)
    launch apk
    (be sure that option install trusted apps is disabled on you device)
    there you go
    android auto is installed and should work
    mclovin5799 likes this.
  12. mclovin5799
  13. Stefke1974
    Froyo Jul 15, 2018
  14. toastytoast1234
    Marshmallow Jul 15, 2018
    toastytoast1234 , Jul 15, 2018 :
    But you still felt the need to create a new thread instead of contributing to the existing ones?
    That's probably worse than the people who don't even bother to look in the first place.
  15. Stefke1974
    Froyo Jul 15, 2018
    seems old threads are not in OP6 section
    that is why i opened new one
    and yes i did search first
    but even old threads are not really helpfull
  16. Stefke1974
    Froyo Jul 15, 2018
    just installed latest version of android auto
    still same issue
    it is defenetly an OP problem
    not a car issue. as other phones work perfectly in my car even old huawei p8 lite works perfectly
    bug hunters of OP say this will be fixed in next update
    but when will this update be released?
    tested devices:
    - huawei p8 lite
    - samsung s6, s7 and even s9
    - huawei Y6
    these device work without any issue
    only OP6 has this problem.
    risafov likes this.
  17. gravindrar
    Cupcake Jul 16, 2018
    gravindrar , Jul 16, 2018 :
    Please fix this bug ASAP
    I have been using android auto everyday. But after buying one plus 6 i couldn't
    risafov and Stefke1974 like this.
  18. Hikari691
    Cupcake Jul 20, 2018
    Hikari691 , Jul 20, 2018 :
    Same problem on my Renault Clio 4 2018 with R-link Evolution. Works with huawei mate 9 and galaxy s6 but not working with OP6.
    Stefke1974 likes this.
  19. Cully1968
    Cupcake Aug 12, 2018
    Cully1968 , Aug 12, 2018 :
    I'll share my OP6 AA experience (2017 Ford F-350 with Sync 3):
    1) First month, everything worked great
    2) Around the end of June, I started having Pandora issues, wouldn't load. Waze still worked. Tried uninstall of both AA & Pandora, clearing cache, etc.... same result. I found that if I opened Pandora before I connected to my truck, all worked. So, I installed an app that detects Bluetooth and allows the opening of an app automatically (Bluetooth Connect and Play). Solved my issue. Can set app to close at bluetooth disconnect too. Nice app! I needed this for one other Android phone a couple years ago. Phones since have not needed this, until my OP6 issue.
    3) New problem: I enabled face unlock. When plugging into my Sync 3, my phone would unlock (as it should because I'm looking at it). AA would not work at all (nothing, could not connect) with phone screen on and phone unlocked. So, as I've seen on other discussions, my OP6 must be locked and display off when plugging into AA. Solved by disabling face unlock. Bummer because face unlock is a great feature!
    AA works great now, with my 2 work-arounds. I use it every day, multiple times per day... Waze & Pandora are on every time I enter my truck, sometimes switch to Google Maps & Google Play music, all are good. I plug in and music plays in under 5 seconds and Waze is ready to go. Hope this helps.
    risafov likes this.
  20. france42
    Honeycomb Jan 12, 2019
    france42 , Jan 12, 2019 :
    i tried your suggested fix by disabling "face unlock" on my VW -sony xav100 head unit, oneplus 6, and miracle! i got back my ability to use voice "ok google" commands with AA! i've been searching for months for a workaround. thanks for posting and sharing! it worked with somebody! it also seems to have alleviated problems i have connecting with media (all of the above and below occuring since Pie update).
    i still looking for a solution to inability to send messages via whatsapp. also phone (headunit) doesn't ring when i receive a call.
    in any case thanks a million!
