12
[FIX] Android System battery drain
  1. Jeffreyvdv3lde
    Jelly Bean Aug 21, 2015
    Jeffreyvdv3lde , Aug 21, 2015 :
    Uhmm. Go to settings - all your applications - Look for Google Play services - Manage space / data - Clear all data. But, I don't have Miui 6, so I can't really help you with that.
    #81
  2. merewoodbebox
    merewoodbebox , Aug 21, 2015 :
    LOL this actually worked, thanks alot, hasnt completely go but android OS is halfed so im happyyyy
    #82
    Jeffrey98 likes this.
  3. Jeffreyvdv3lde
    I don't have a Smartwatch, so I don't know how it works. Shouldn't be a problem though.
    #83
  4. sahil7827
    Gingerbread Aug 22, 2015
    #84
  5. sahil7827
    sahil7827 , Aug 22, 2015 :
    it's called typing without testing
    i have tested
    cm12.1
    exodus
    Euphoria-OS
    cr droid
    yes sultanxda. (10 days ago)
    mokee, xenonhd, *******
    currently using cm12 .1 with same issue
    #85
  6. blueq
    Honeycomb Aug 22, 2015
    blueq , Aug 22, 2015 :
    @Jeffrey98
    Now we're cooking. Have applied your fix just waiting for the improvement.
    If I may make a suggestion, edit your original post to: " Mange Data or Manage Space "to eliminate confusion.
    Thank you for your contribution. :):cool::D
    #86
  7. Jeffreyvdv3lde
    Jelly Bean Aug 22, 2015
    Jeffreyvdv3lde , Aug 22, 2015 :
    I'll change it :)
    Edit: Done!
    #87
    blueq likes this.
  8. TheoneNonly
    Gingerbread Aug 26, 2015
    #88
  9. Jeffreyvdv3lde
    Jelly Bean Sep 7, 2015
    Jeffreyvdv3lde , Sep 7, 2015 :
    Yep. It has worked for me. SOT is 4,5 hours for me at 20% left...
    #89
  10. ndy4eva
    Gingerbread Oct 14, 2015
    ndy4eva , Oct 14, 2015 :
    I hope this resolve an issue with my oneplus. It wiped out my Android Wear pair and configuration. I won't pair it for now and see if this resolve "Android System" battery drain.
    #90
  11. deepak9790
    Eclair Nov 3, 2015
    deepak9790 , Nov 3, 2015 :
    IT IS SHOWING.. ALL THIS APPS DATA WILL BE DELETED PERMANENTLY..INCLUDES ALL FILES,SETTINGS,ACCOUNTS,DATABASES,ETC,,
    WHAT SHOULD I GIVE?? CANCEL or OK???
    ANS PLZ..WILL IT DELETE ALL THE APPS WHICH I HAVE DOWNLOADED FROM PLAY STORES.
    #91
  12. vicky_kirar
    Donut Nov 4, 2015
    vicky_kirar , Nov 4, 2015 :
    in standby mode my battery drain 8-9% at night in 6-7hr while data and wifi is off.....any solution for that..?
    #92
  13. Jeffreyvdv3lde
    Jelly Bean Nov 4, 2015
    Jeffreyvdv3lde , Nov 4, 2015 :
    Hi, it'll only wipe some shitty data for the Google Play Services app. No apps will be deleted.
    #93
  14. Jeffreyvdv3lde
    You followed all the steps? It should minimalize the battery drain. As for now, I know the battery drain should be fixes in Android M.
    #94
  15. Jeffreyvdv3lde
    Did it work for you?
    #95
  16. deepak9790
    Eclair Nov 4, 2015
    deepak9790 , Nov 4, 2015 :
    YEAH DONE.. LET YOU KNOW MY STATUS IN COUPLE OF DAYS..
    #96
  17. diegocipa
    Eclair Nov 9, 2015
    diegocipa , Nov 9, 2015 :
    hey, i have been having the same problem with android system draining my battery the past month or so, today after 8 hours of sleep it went 40% of battery down! i have tried what you said a couple of times but nothing happens. even flashed the latest cm rom, even reseted the phone, nothing. im ataching the photos from today.
    ps.i have talked on this thread more for the same issue https://forums.oneplus.net/threads/oneplus-one-battery-drain.400672/
    #97
  18. Jeffreyvdv3lde
    Jelly Bean Nov 9, 2015
    Jeffreyvdv3lde , Nov 9, 2015 :
    You're also using the privacy guard to make sure Android System doesn't keep your phone awake.
    #98
  19. diegocipa
    Eclair Nov 9, 2015
    am I or should I?
    #99
  20. Jeffreyvdv3lde
    You should, I forgot to put the questionmark over there. Give it a try.
