18
[FIX] Flash Fail for CM12 - A0001 conflict
  1. @BH!
    Ice Cream Sandwich Apr 14, 2015
    @BH! , Apr 14, 2015 :
    Hi All,
    Its obvious that every1's so excited about the CM12s rollout.:rolleyes: You got every reason to be.:cool:
    Lets get to the point here, I created this thread just to let you all (people who are facing this issue in recovery) know how to make it go away.;)
    Issue: While you try t install the CM12s package (zip) in recovery it fails statig the package is meant for A0001.
    Reason: The condition in the updater script.(Similar to conflict in MIUI ROM - if you had tried it you may very well know.)
    FIX:
    1.Open the zip using WinRAR or 7ZIP. and decompress the package to local.
    2.Open the package and navigate to \META-INF\com\google\android
    3.Open updater-script file in a text editor.
    4.Add the below lines to the file (at the beginning) and save it. (SEE EDIT-1)
    assert(getprop("ro.product.device") == "A0001" || getprop("ro.build.product") == "bacon" || abort("This package is for \"A0001\" devices; this is a \"" + getprop("ro.product.device") + "\"."););
    5.Compress the folder back to zip.
    6.Flash and enjoy.:cool::cool:
    Lemme know if you are facing any issues. PEACE!!:):)
    DISCLAIMER: Always take a NAND backup and am not responsible for your device getting bricked.:p:p
    EDIT-1: I just downloaded the CM12s zip and could see the code
    assert(getprop("ro.product.device") == "A0001" || getprop("ro.build.product") == "A0001" || abort("This package is for device: A0001; this device is " + getprop("ro.product.device") + "."););
    So all u gotto do is replace this line with the above one.
    EDIT - 2: Flash latest TWRP and flash the zip. (Better way to Bypass all the above stuff):D
  2. SHAKHILONIEL
    Gingerbread Apr 14, 2015
  3. @BH!
    Oh ye of li'l faith...:p:p
  4. SHAKHILONIEL
  5. jatish123
    jatish123 , Apr 14, 2015 :
    Can you give me the link for the zip
  6. @BH!
    add it to the top of all lines.
  7. MrTeejay619
  8. imcr7
    Donut Apr 14, 2015
    imcr7 , Apr 14, 2015 :
    Just flash the stock recovery, then flash update, then flash twrp again. I solved this way
  9. Astraion
    kolyan2k likes this.
  10. SHAKHILONIEL
  11. @BH!
    See the edited post.
  12. SHAKHILONIEL
    SHAKHILONIEL , Apr 14, 2015 :
    What do I need to flash it
  13. SHAKHILONIEL
  14. warrior82
    Honeycomb Apr 14, 2015
    warrior82 , Apr 14, 2015 :
    A programmer mind :cool:
    @BH! likes this.
  15. awadi888
    awadi888 , Apr 14, 2015 :
    all i did was flash the newest version of TWRP and it worked for me. no need to modify the zip.
    SHAKHILONIEL likes this.
  16. SHAKHILONIEL
  17. patstar5
    Jelly Bean Apr 14, 2015
    Madement likes this.
  18. kk22
    kk22 , Apr 14, 2015 :
    Did you do adb sideload or installed directly from within TWRP?
  19. awadi888
    I installed directly within twrp
    kk22 likes this.
  20. kolyan2k
    kolyan2k , Apr 14, 2015 :
    thanks. this does the trick
    Astraion likes this.
