Fix for Battery Drain/ Slow Charging/ Lag in Gaming /Stability Issues and Other Bugs via OnePlus 6T
  1. riyaz7861
    Eclair Sep 27, 2020
    riyaz7861 , via OnePlus 6T , Sep 27, 2020 :
    Hi All,
    If you guys are facing Battery Drain/ Slow Charging/ Lag in Gaming /Stability Issues and other bugs after updating to Android 10 then downgrade to Oxygen OS Version 9.0.16 (OnePlus 6T)/ 9.0.8 (OnePlus 6).
    I have upgraded and downgraded my phone multiple times and i see that the best Oxygen OS Version is 9.0.16 (OnePlus 6T)/ 9.0.8 (OnePlus 6) which doesn't have any issues.
    There are currently multiple bugs in Android 10 so wait till OnePlus fix these issues.
    Hope it helps :)
    Thanks @ironass for the below points
    Note: 1. Backup your data because this will wipe your phone
    2. You will lose the last 13 months of Android Security updates.
    3. You will lose all the OnePlus system optimisations, new features and bugfixes introduced in the last 13 months.
    4. You will not be eligible to receive Android 11 OTA when it is released unless you manually flash at least 2 updates.
    Thank You
    ironass likes this.
  2. pablofg1978
    Nougat Head Moderator Sep 27, 2020
    pablofg1978 , Sep 27, 2020 :
    Hello there,
    If you have problems with android 10, you should inform them to oneplus using the bug report platform so it can be fixed (you have submitted 0 bug reports so far)
    Downgrading will let you with old security updates and other kinds of problems.
    I have a oneplus 6t with the last stable update and I dont have any of those issues, so maybe the problem is not with the update but with the apps that you use that are poor developed and causing you those issues.
    ironass likes this.
  3. riyaz7861
    Eclair Sep 27, 2020
    Hello, I know that security patch is older what are other problems?
  4. pablofg1978
    I dont know, but I bet that you will find some
  5. ironass
    Lollipop Sep 27, 2020
    ironass , Sep 27, 2020 :
    It should be noted that downgrading to OxygenOS 9.0.16 is for the OnePlus 6T and..
    1. Will wipe your phone
    pablofg1978 and riyaz7861 like this.
  6. riyaz7861
    Eclair Sep 27, 2020
    I Agree :)
  7. ironass
    It might be a good idea to include those caveats in any future recommendations you make regarding downgrading, in fairness to users so that they fully know what they are letting themselves in for.
    Caomhin and pablofg1978 like this.
  8. riyaz7861
    Eclair Sep 27, 2020
    Sure, Thanks, this is my first post will add these points in first post
    ironass likes this.
