[FIX] How to FIX the touch screen issues [TUTORIAL]
  1. AidanGee
    Gingerbread Aug 1, 2014
    AidanGee , Aug 1, 2014 :
    Hey everyone, hopefully this helps a few people!
    This 99% fixes the "quick typing" ghost touches issue
    1. Download and run Terminal emulator
    Then type the following:
    1. su
    2. cd /sys/class/input/input0
    3. cat baseline_test
    Then restart, now when typing fast the screen wont mess up and do ghost touches
    Note: This is not for the pillow grounding issue
    arof likes this.
  2. Saprophator
    Froyo Aug 1, 2014
  3. AidanGee
    kevinha likes this.
  4. Saprophator
    Froyo Aug 1, 2014
    Saprophator , Aug 1, 2014 :
    Nope. all the command does is displaying a file. There is no way it is fixing any of the current problems.
    armmani2001 likes this.
  5. AidanGee
    sam841230s likes this.
  6. Saprophator
    Froyo Aug 1, 2014
    I don't have any issues with the touch sensitivity so I can not confirm.
    But there is literally no way executing a cat on any file does something else then displaying that file...
  7. ilea
    Donut Aug 1, 2014
    ilea , Aug 1, 2014 :
    Thanks !
    Really fixed my issue for now.
    Swiftkey working as it should be working :)
    AidanGee likes this.
  8. AidanGee
    I'm glad i could help you for now, hopefully this "fix" gets
    looked into properly and released in some sort of update :)
    Like i said bro, i don't know how it works but see the above quote, it is working :)
  9. Saprophator
    Froyo Aug 1, 2014
    My bad, just checked. the baseline_test is no "file" its more like a link, and something seems to be executed in the backround upon calling it. Weird, but good find for people with that issue.
  10. ilea
    Donut Aug 2, 2014
    ilea , Aug 2, 2014 :
    Ok I was too quick... At first it seemed to help.. But now it's the same as before...
    I have rebooted my device directly after the command...
    Edit : did the commands again and it seems that it is better now..
    Maybe reboot was the culprit
  11. Tainguyen17
    Froyo Aug 2, 2014
    Tainguyen17 , Aug 2, 2014 :
    Hi guys. Im new to android. What is this quick typing or ghost touches? I've been learning a lot for my phone.
  12. notfixingit
    Eclair Aug 2, 2014
  13. AidanGee
    Gingerbread Aug 2, 2014
    AidanGee , Aug 2, 2014 :
    This fix appears to wear off after a while or after a reboot but the good news is that the issue is software related :)
    SushiR likes this.
  14. deuse
    Jelly Bean Aug 2, 2014
    deuse , Aug 2, 2014 :
    This l only fix the keyboard and not the multi touch problems which is hardware. And yes it reset's
    after a time\reboot, needs a OTA fix.
  15. jandresheredia82
    Cupcake Dec 16, 2014
    jandresheredia82 , Dec 16, 2014 :
    Hi Guys,
    My problem is with the screen getting on without touching. It happens every few hours. Also, this morning when I got up, I couldn't use my phone even when I hadn't turned off the previous night. I had to keep pushing the On button until it got alive again.
    Could anybody advise if I'm doing something wrong with the Awake mode, the screen settings or whatever can be creating this?
    Sorry for the question but I got the phone just two days ago and I'm still getting familiar with it.
    Cheers.
  16. jandresheredia82
    Cupcake Jan 3, 2015
    jandresheredia82 , Jan 3, 2015 :
    Just in case that it's useful for anybody. It had to be with the connectivity. Whenever the phone was losing the wifi signal, the phone was getting on. Once I did a hard reboot, this has been solved.
  17. sudnut
    Ice Cream Sandwich Feb 10, 2015
  18. juecart
    Cupcake Mar 2, 2015
  19. bilalrazzaq
    Cupcake Apr 1, 2015
  20. mika125
    Donut May 12, 2015
