66
[FIX] Wrong Pin/Pattern when restoring TWRP Nandroid Backup
  1. Icebird00 Gingerbread Dec 29, 2016
    Icebird00, Dec 29, 2016 :
    Hi thanks it works great. First i don't see the folder/files, but after mounting data/cache they are there. just had to rename the locksettings* to get around my pattern lock.
  2. G_Luis_Barba_uPCh Cupcake Jan 6, 2017
    G_Luis_Barba_uPCh, Jan 6, 2017 :
    How can you delete these files via adb. I am locked out of my twrp, because it asks for some password. I've tried my lockscreen passcode, but its refusing to unlock. Pls help
  3. jansvanda Ice Cream Sandwich Jan 9, 2017
  4. Bernie55 Cupcake Mar 10, 2017
    Bernie55, Mar 10, 2017 :
    Fantastic, Thanks! I was pretty disappointed when I couldn't use my backup and had to set the phone up again.
  5. Manikandan Cupcake Mar 24, 2017
  6. manoj Eclair Apr 4, 2017
    manoj, Apr 4, 2017 :
    TWRP not giving access to storage, asking for password which i didnt set.
    I removed the files using ROMTOOLBOX LITE
    because TWRP not giving access.
    but it is not woking.
  7. mbakshi Cupcake Apr 6, 2017
  8. snowcat98 Eclair Apr 9, 2017
    SirRhor and iCoerce like this.
  9. gabrielmm Cupcake Apr 15, 2017
    gabrielmm, Apr 15, 2017 :
    Perfect Thank you! what worked for me was only deleting the gatekeeper.pattern.key (only that file)! fingerprint was working fine! if you have twrp you can use the file manager from it too to delete, easy and simple.
    Edit, I have to delete locksettings.db too. otherwise security options in android crashes.
  10. iCoerce Froyo Apr 18, 2017
    iCoerce, Apr 18, 2017 :
    absolute life-saver bro... you just made every backup I've ever had so easy... not all heroes Wear capes
    SirRhor and snowcat98 like this.
  11. iCoerce Froyo Apr 18, 2017
  12. hanschristianandersen Cupcake Jul 16, 2017
  13. DaniFilth84 Cupcake Aug 3, 2017
    DaniFilth84, Aug 3, 2017 :
    Thank you very much my friend, you saved me a few days of restoring everything.
    Cheers.
  14. Math. Cupcake Aug 13, 2017
  15. v0 HaVoK 0v Ice Cream Sandwich Sep 2, 2017
    v0 HaVoK 0v, Sep 2, 2017 :
    For the OnePlus 5 does this happen also? Was trying to see if anybody talks about it for op5 but can't find a thread anywhere.
    If it does happen. Can you stop this from happening by removing your lock and fingerprint before making the backup?
  16. F_Andrea_Ippolito_ZsRS Ice Cream Sandwich Sep 14, 2017
    F_Andrea_Ippolito_ZsRS, Sep 14, 2017 :
    To avoid having to re-register all of your fingerprints, you can just delete these files:
    /data/system/locksettings*
    Then you just have to choose again the unlock method, from the default "swipe" to sequence (or whatever you used previously, at the time the TWRP backup was taken), and you're set! No more need to re-register fingerprints after a restore :)
  17. dblaster Honeycomb Sep 20, 2017
  18. alan_helper Cupcake Oct 7, 2017
    alan_helper, Oct 7, 2017 :
    I dont found this two files on /data/system
    • password.key
    • pattern.key
    But works! Many thanks!!
    #38
  19. puteraracing01 Cupcake Dec 7, 2017
    #39
  20. puteraracing01 Cupcake Dec 7, 2017
    #40
