73
[FIXED] [FOR GOOD] Microphone issue
  1. jordym
    Honeycomb Dec 30, 2014
    jordym , Dec 30, 2014 :
    Hi this is for those who suffer from the microphone issue. I finally stumbled upon a solution:
    if updating, rooting and changing mixer_paths did not work. Here is how you can fix it.
    First you need a rooted device.
    If you could, edit using a file explorer such as ES Explorer with root access
    /system/build.prop. Change
    ro.qc.sdk.audio.fluencetype=fluence
    to
    ro.qc.sdk.audio.fluencetype=none
    Then, edit /system/etc/audio_platform_info.xml
    <device name="SND_DEVICE_IN_HANDSET_MIC" acdb_id="40" />
    to
    <device name="SND_DEVICE_IN_HANDSET_MIC" acdb_id="4" />
    Reboot.
    this is the reason why even flashing mixer_paths was useless. if required, i will be able to post links for the files involved in other to flash them.
  2. Hanness
    Donut Jan 1, 2015
  3. shawn0223
    Gingerbread Jan 1, 2015
    shawn0223 , Jan 1, 2015 :
    Yes, which issues are you referring to? And what exactly is it doing when we edit those lines?
  4. Hanness
    Donut Jan 1, 2015
    Hanness , Jan 1, 2015 :
    I've did some research and this should suppress the noice cancelling. In my case the problem that the other side can't hear me during a call (they can only hear me on speaker mode) is fixed when I put my finger on the other microphone (next to the camera), so I'll try this solution tomorrow.
  5. toter4
    Donut Jan 2, 2015
    toter4 , Jan 2, 2015 :
    Has anyone else tried this solution? I've been having a problem with poor sound quality from the microphone in calls. The person I call complains that they can barely hear me. I've tried calling myself and I can confirm this. In my case I've also noticed that there's an echo whenever I said anything using the OPO. Seems like this could be due to the multiple microphones and a glitch in the noise-cancelling function.
  6. vdd65
    Jelly Bean Jan 2, 2015
  7. kuhler
    Gingerbread Jan 2, 2015
    kuhler , Jan 2, 2015 :
    This =link=>
  8. Hanness
    Donut Jan 2, 2015
    Hanness , Jan 2, 2015 :
    It did not solve my problems unfortunately. I can only still call properly when I put on speakermode.
  9. erik725
    Honeycomb Jan 2, 2015
    erik725 , Jan 2, 2015 :
    This solved my problems during the call, excellent now the other person can hear me, thank you very much for the answer!!
    gmbruine, Oszy and SoniaB like this.
  10. dreniacdre
    KitKat Jan 2, 2015
    dreniacdre , Jan 2, 2015 :
    There is one in the top too, right?
    saadsid11 likes this.
  11. AuntieAnn
    Ice Cream Sandwich Jan 2, 2015
    AuntieAnn , Jan 2, 2015 :
    Thank you, kind citizen of OP. Here, I have procured 3 lovely ladies for a sacrifice in your honor. For those that try it, let us know how it goes.
  12. Hanness
    Donut Jan 2, 2015
    The solution here didn't work on its own. Now that I also modified the mixer-paths.xml, everything seems to work fine again.
    Dynamix likes this.
  13. Oxholm
    Donut Jan 2, 2015
    Oxholm , Jan 2, 2015 :
    Hi, I have the problem too, where the other person can't hear me.
    I've modified my mixer-paths.xml and it helped (in some cases only apparently).
    Should I revert the mod, for this to work or should I be okay?
    saadsid11, NISCHAL99 and JamesNicky like this.
  14. Oxholm
    Donut Jan 3, 2015
    Oxholm , Jan 3, 2015 :
    Can someone tell me this? :/
  15. Hanness
    Donut Jan 3, 2015
    Hanness , Jan 3, 2015 :
    What do you mean exactly?
    In my case it seems to work when I did both the modifications in this thread and adapting the mixer-paths.xml. You can always try it and see what works best, the changes are easily reversible.
  16. Oxholm
    Donut Jan 3, 2015
    tamzak likes this.
  17. Oxholm
    Donut Jan 3, 2015
    lol... Now the phone doesn't even boot - How great!
    *Blows off head*
    marek.maurizio likes this.
  18. IWantOneNow
    KitKat Jan 3, 2015
    IWantOneNow , Jan 3, 2015 :
    You can just reflash "system" in fastboot. Is your bootloader unlocked?
  19. Oxholm
    Donut Jan 3, 2015
    yea, it is :) How much will I wipe doing that? :p
    I'm on Lollipop btw., if that changes anything :)
  20. Oxholm
    Donut Jan 3, 2015
    "Unable to mount system" - auch..
    How do I reflash "system" then?
    Edit: Fixed it by re-flashing my ROM..
    So, note to all: Don't do this on Lollipop - At least, if you did, do tell me how you solved it :)
