2
Flash Light Problem via OnePlus 8T Aquamarine Green
  1. khmahfuz , via OnePlus 8T Aquamarine Green , Aug 4, 2021 :
    Flashlight photo is so bad. When I try to take a photo at night. Its really getting bad view after capturing a photo. Check the screenshot
    D.Ganesh and rHITkM. like this.
  2. puccellino
    Lollipop Aug 5, 2021
    Best Answer
    puccellino , Aug 5, 2021 :
    Do you have any form of screen protector on over the camera lens?
    khmahfuz, Gor. and rHITkM. like this.
  3. rHITkM.
    Ice Cream Sandwich Aug 4, 2021
    rHITkM. , Aug 4, 2021 :
    Please try clearing Cache of the Camera app, then Restart. See if that helps.
    Gor.V likes this.
  4. rHITkM.
    Ice Cream Sandwich Aug 5, 2021
    rHITkM. , Aug 5, 2021 :
    Yeah you might be right! I think It's DIFFUSION OF LIGHT.
    Attachment shows the phenomenon of diffusion of light in the glass from the source of light.
    Same thing could be the problem with the user's device while trying to take photo using flash light in the dark.
    Gor.V likes this.
  5. khmahfuz , via OnePlus 8T Aquamarine Green , Sep 25, 2021 :
    Hi,
    yes. I used a camera protector. It's the problem. I removed it and after the problem has been solved.
    Thanks for your suggestion.
    puccellino likes this.
