Flashable Cyanogen os 12 file
  1. pecana
    Honeycomb Apr 14, 2015
    pecana , Apr 14, 2015 :
    You
    You can Flash it via TWRP :) here the post
    roshan.india likes this.
  2. sahil7827
    Gingerbread Apr 14, 2015
    sahil7827 , Apr 14, 2015 :
    did u try it......
  3. roshan.india
    Ice Cream Sandwich Apr 14, 2015
  4. therealrakshit
    Eclair Apr 14, 2015
    therealrakshit , Apr 14, 2015 :
    can i flash it over oxygen os? if yes any source/screenshot?
  5. pecana
    Nope you can't I'm sure it will not work, You MUST do a factory reset before flashing it if you come from a different ROM.
  6. Jupeeeeee
    Jelly Bean Apr 14, 2015
    Jupeeeeee , Apr 14, 2015 :
    Stop talking shit. Came from 12 nightlies and i didnt clear anything, lost nothing and everything works. And cm12 is not the same rom as cos12.
  7. pecana
    Honeycomb Apr 15, 2015
    pecana , Apr 15, 2015 :
    Dude he was coming from Oxigen OS! Stop reading only a part of the reply! You just make confusion!
    Shame on you ;)
    sudnut likes this.
  8. Jupeeeeee
    Jelly Bean Apr 16, 2015
    Jupeeeeee , Apr 16, 2015 :
    Doesnt matter, nightlies are still a different rom ;)
  9. pecana
    Honeycomb Apr 20, 2015
    pecana , Apr 20, 2015 :
    But, just for information, changing ROM without wiping data may cause high instability, battery drain and random app crash in 90 % of cases :) Every developer's team suggest to make a full wipe before install a new rom (if it's not an upgrade of the same) to get the best from it ;)
  10. Jupeeeeee
    Jelly Bean Apr 22, 2015
    Jupeeeeee , Apr 22, 2015 :
    Still came from nightlies withput wiping anything and works normally :p
