24
[FLASHABLE ZIP] Enable integrated superuser
  1. jak
    Ice Cream Sandwich Aug 2, 2014
    jak , Aug 2, 2014 :
    Somewhere in recovery.
    But the new .zip is signed now, so it should not be needed anymore anyway.
    #41
  2. TeamValor91
    Community Veteran Aug 2, 2014
    #42
    jak likes this.
  3. TeamValor91
    Community Veteran Aug 12, 2014
    #43
    Freezer likes this.
  4. jak
    Ice Cream Sandwich Aug 12, 2014
    jak , Aug 12, 2014 :
    I prepared my part, I'm only waiting for Cyanogen Inc to publish the factory images which will happen once the initial OTA rollout is complete. So, it should be here end of week.
    #44
    TeamValor91 and Freezer like this.
  5. jak
    Ice Cream Sandwich Aug 13, 2014
    jak , Aug 13, 2014 :
    NEW: A build that works with all kernels, and XNPH30O (and most likely later versions):
    http://jak-linux.org/cm/cm-unofficial-11-signed-superuser-light.zip
    (this only enables root for apps, adb root will not work, as adb blocks it without ro.debuggable=1).
    If you want to get rid of it (or flash another su), rm /system/etc/init.d/01su and /system/xbin/su.
    #45
    TeamValor91 likes this.
  6. risky1301
    Lollipop Aug 13, 2014
    risky1301 , Aug 13, 2014 :
    I am drfunelty going to try this, now will this wipe your phone content? Do I need to back first?
    #46
  7. jak
    Your phone is only wiped if you need to unlock your bootloader. Otherwise, you can just flash this from TWRP or other custom recovery.
    #47
  8. SunBoy
    Gingerbread Aug 13, 2014
    SunBoy , Aug 13, 2014 :
    Try to use default recovery to flash and got error........
    #48
  9. jak
    You need a custom recovery.
    #49
  10. SunBoy
    How can i flash custom recovery without unlock bootloader ?
    I just want to root my phone than use tatinum backup, but after update to the updated firmware, lost root and i can't root it again.
    #50
  11. jak
    You cannot flash a recovery without unlocking anymore. You used a security bug in previous versions that has been fixed now. There's no known way to root without unlocking.
    #51
    SunBoy likes this.
  12. gmgriffin
    Jelly Bean Aug 13, 2014
    gmgriffin , Aug 13, 2014 :
    Thanks for the info.
    #52
  13. SunBoy
    Thank you for your reply.
    #53
  14. jak
    Update (light): Fixed a minor issue in the light version that blocked custom init.d scripts from running.
    #54
  15. r00t0rd34d
    Honeycomb Aug 14, 2014
    r00t0rd34d , Aug 14, 2014 :
    Hi Jak,
    first of all, thanks for your work.
    Now my question, are there differences between the cm own superuser app and e.g SuperSU ?
    e.g functions such as logging or is it a integrated version of koushiks app ?
    #55
  16. jak
    Ice Cream Sandwich Aug 14, 2014
    jak , Aug 14, 2014 :
    It's an integrated version of koush's superuser. And it has logging and various other options.
    #56
  17. r00t0rd34d
    #57
    opon3 likes this.
  18. tagline15
    Gingerbread Aug 14, 2014
    tagline15 , Aug 14, 2014 :
    Just stumbled across this and it sounds amazing. :D
    So the light version just flashes the su binary and not the debug kernel? Is that right?
    #58
  19. jak
    Yes. This way it's not as powerful (no adb root), but still as powerful as all other su methods.
    #59
  20. tagline15
    Very cool. :cool:
    But I guess, it doesn't survive an OTA update, does it?
    #60
