24
[FLASHABLE ZIP] Enable integrated superuser
  1. jak
    Ice Cream Sandwich Aug 14, 2014
    jak , Aug 14, 2014 :
    Not if they keeping deleting unknown files from /system in future OTAs. It would be easy to add a OTA-survival mode, but I'm not sure it's worth it.
    #61
    tagline15 likes this.
  2. tagline15
    Gingerbread Aug 14, 2014
    tagline15 , Aug 14, 2014 :
    Ok, thanks. I will definitely try this out. :D
    #62
  3. tagline15
    Gingerbread Aug 16, 2014
    tagline15 , Aug 16, 2014 :
    I flashed the light version today and it works great. Thanks for this great solution. :D
    #63
  4. Freezer
    Cupcake Aug 19, 2014
    #64
  5. jak
    Ice Cream Sandwich Aug 20, 2014
    jak , Aug 20, 2014 :
    I now pushed the build with the embedded boot.img for XNPH30O. I will most likely phase this out in the future though, as you can just flash the light one and then (if you need adb root) flash the debuggable boot.img yourself.
    I did not test the full build myself (as I use the light one), but it is created automatically and should thus work without issues.
    #65
  6. jak
    Future versions of the light build might include the ability to survive OTA updates, or it will be provided as a separate add-on.
    #66
    Freezer likes this.
  7. thegdub
    Jelly Bean Aug 20, 2014
    #67
  8. jak
    Now I'm curious: How is flashing one of these zips more work then flashing a SuperSU zip?
    #68
    PLPeeters likes this.
  9. Freezer
    Cupcake Aug 22, 2014
    Freezer , Aug 22, 2014 :
    Could flashing the light version, be the reason I cannot sideload the OTA update?
    #69
  10. jak
    Ice Cream Sandwich Aug 22, 2014
    jak , Aug 22, 2014 :
    Mmh, I don't think so-
    #70
  11. jak
    light now updated for changes XNPH33R, complete list of changes:
    • Add symlink /system/bin/su which was removed in XNPH33R
    • Fix permission of init.d script to be 755 instead of 6755
    #71
    rezor92 likes this.
  12. jak
    I'll use the XNPH33R update to check my new OTA survival script. If everything works fine (which it should), the next version will include that, so there would no need to reflash this anymore after an upgrade.
    #72
  13. tagline15
    Gingerbread Aug 22, 2014
    tagline15 , Aug 22, 2014 :
    Great. Looking forward to it. :D
    #73
  14. BeGayDoCrime
    BeGayDoCrime , Aug 22, 2014 :
    You're a great person, jak! Keep it up :)
    #74
    Jeffr0 likes this.
  15. jak
    Updated the light version, changes since the last version:
    • Survive OTA updates (as long as /data is not wiped)
    #75
  16. tagline15
    Gingerbread Aug 23, 2014
    #76
  17. BeGayDoCrime
    Cupcake Aug 24, 2014
    #77
  18. jak
    Ice Cream Sandwich Aug 24, 2014
    jak , Aug 24, 2014 :
    Do you need adb root? If not, use the light version. The "full" version requires new factory images to be posted first. This also means that full cannot survive OTA updates.
    #78
    Jeffr0 likes this.
  19. BeGayDoCrime
    BeGayDoCrime , Aug 24, 2014 :
    I wouldn't say I 'need' it, but messing around on the /system partition is way more convenient through my computer. Oh well, I'll go with light for now.
    #79
  20. PLPeeters
    KitKat Aug 24, 2014
    #80
