7
Flashed to CM12 Nightly
  1. MatteoCarrara
    Gingerbread Apr 10, 2015
  2. DaxNagtegaal
    Marshmallow Apr 10, 2015
    iowamatt likes this.
  3. giaur500
    Jelly Bean Apr 10, 2015
    giaur500 , Apr 10, 2015 :
    Yep, Lollipop is way better and curtent nightlies are really stable.
  4. iowamatt
    Eclair Apr 10, 2015
    iowamatt , Apr 10, 2015 :
    My biggest gripe with Lollipop is how it handles mute/volume. I still don't quite have it figured out.
    DaxNagtegaal likes this.
  5. DaxNagtegaal
    DaxNagtegaal , Apr 10, 2015 :
    xposed is your thing then
    Get xposed > get True Silent Mode
    that changes it to be the exact same as on kitkat.
  6. iowamatt
    Eclair Apr 10, 2015
  7. DaxNagtegaal
    hell yeah.
    Do note that with each ROM update you have to re-flash xposed and reinstall your modules.
    Kind of annoying but that's the way it is since xposed installs in /system and /system gets reflashed when you update.
    You shouldn't update nightlies every day anyway, better to stick to weekly.. or more often if you must
  8. giaur500
    Or accept things and not install xposed
  9. DaxNagtegaal
    Really? Xposed is an amazing addition to Android it does so much more than you know.
  10. Knight_1183
    Honeycomb Apr 10, 2015
    Knight_1183 , Apr 10, 2015 :
    Hardbrick= Phone does not even turn on (It does not necessarily need that you can not fix it).
    Soft Brick= Phone turns on but you cannot either boot the OS or go into recovery or Fastboot Mode.
  11. giaur500
    Currently unstable on Lollipop, not recommended
  12. DaxNagtegaal
    lol most modules are updated for 5.0 just make sure they are before you install them
  13. giaur500
    Maybe... but I see reasons to use them on pure aosp only and not on CM which is already customized.
    Also, yes, xposed on art is still experimental and not guaranted to be not causing problems
  14. DaxNagtegaal
    Sigh
    Greenify
    Amplify
    Restore notification ticker on Lollipop
    True silent mode
    YouTube background playback
    Adaway
    OxygenOS specific: Gravitybox, AppOps
  15. giaur500
    You don't need xposed for AdAway, it's independent app. The rest... I don't need personally. GravityBox is good for aosp though
  16. brunomd
    Eclair Apr 10, 2015
    brunomd , Apr 10, 2015 :
    One question...maybe stupid...but...does the nigth versions are upgrade to cm12 by OTA?
    Thanks
  17. kadowson
    Ice Cream Sandwich Apr 10, 2015
    kadowson , Apr 10, 2015 :
    Nightlies is good... maybe better than 12S. I've read that there will be additions to nightlies that never made it to 12S.
  18. giaur500
    Yes. For example, built in root access
    #38
    kadowson likes this.
