Flashed Viper4android, can't get it to work....NEED HELP..!!!
  1. Gry1503
    Cupcake May 22, 2016
    Gry1503 , May 22, 2016 :
    I installed busybox, Changed Selinux mode to Permissive...Flashed Viper4Android ...and now it doesn't work. Can't uninstall viper now coz I have flashed it. I am Running on COS 13, and most of the methods out their require what i did. Please help me get the viper4android working. Also there is no Specific method to install viper4android mentioned for cos 13. Only methods are for the nightlies build. None for the final COS 13
  2. Yaznas
    Gingerbread May 22, 2016
  3. headphones1
    Jelly Bean May 22, 2016
    headphones1 , May 22, 2016 :
    I even could not get it to work with anything but local music (play music/amazon music) on cm13. hope they update it.
  4. pablofg1978
    Head Moderator Head Moderator May 22, 2016
  5. DonKingKong
  6. rajaspardeshi
    Ice Cream Sandwich May 23, 2016
  7. LiFeLeSSLeGeND
    Honeycomb May 23, 2016
  8. Gry1503
    Cupcake May 23, 2016
    Gry1503 , May 23, 2016 :
    Can you please provide me with the link?
  9. ash23
    Jelly Bean May 23, 2016
    ash23 , May 23, 2016 :
    Download selinux mode changer, change to permissive, now install viper. Change to permissive every time you reboot the device
  10. rajaspardeshi
    rajaspardeshi , May 23, 2016 :
    Not from a thread, but this forum member helped with it. Screenshots of the conversation attached.
    LiFeLeSSLeGeND likes this.
  11. Gry1503
    Thanks man....I just noticed that viper has started working for play music by some miracle. I'll just try to flash the zip and update whether viper started working with other music players or not..!!!!
    rajaspardeshi likes this.
  12. Gry1503
    Not working with other players even on permissive..!!!
    AnEvilVegetable likes this.
  13. niTe_RiDeR_Pro
    niTe_RiDeR_Pro , May 23, 2016 :
    You can uninstall it easily with Titanium Backup app.
  14. niTe_RiDeR_Pro
  15. Gry1503
    Cheers mate. It worked. I am using it on stellio music player... Working fine.
    The only problem I'm facing now is that there's no viper4android folder in my memory. I created it myself and created a Kernel folder so that I can put few irs in it. When I'm trying to load those irs, its not showing any irs in the directory...!!
  16. Gry1503
    Ohh yeah... Nice suggestion.. Completely forgot about that..!!
  17. rajaspardeshi
    niTe_RiDeR_Pro likes this.
  18. rajaspardeshi
    No idea about the missing folder issue:|
  19. lbaty
    Eclair May 23, 2016
    lbaty , May 23, 2016 :
    I had the same problem. repey6 directed me to this post which worked: http://forum.xda-developers.com/showpost.php?p=65132260&postcount=20936
    Basically you need to put your IRS files here: /mnt/runtime/write/emulated/legacy/Viper4Android/Kernel
  20. mapkbalaji
    Cupcake Sep 15, 2016
