Flashing custom ROM, but firmware requiree?
  1. Optimus_Robertus Eclair Jun 23, 2018
    Optimus_Robertus, Jun 23, 2018 :
    Hi all,
    I would like to flash AOSP Extended v5.6 (18-6-2018 version).
    However, in the XDA thread, it says firmware 5.1.2 is required.
    What does this mean? Does it mean I have to flash OOS 5.1.2 first, before I flash this ROM?
    At the moment, I'm on Open Beta 12 (NoLimits), so can I flash this ROM, without first flashing OOS 5.1.2?
    Thanks in advance!
  2. idkwhoiam322 Marshmallow Jun 23, 2018
    idkwhoiam322, Jun 23, 2018 :
    No, firmware is something else. What device do you have?
    Edit:
    Just read, oneplus 5. Will drop link.
    Lancelot_69 and Optimus_Robertus like this.
  3. idkwhoiam322 Marshmallow Jun 23, 2018
  4. Optimus_Robertus Eclair Jun 23, 2018
    idkwhoiam322 likes this.
  5. idkwhoiam322 Marshmallow Jun 23, 2018
    Stuff related to modem, radios, headphone jack etc.
  6. Optimus_Robertus Eclair Jun 23, 2018
    Ahhh. Thanks for clearing that up!
  7. AlexandreP Honeycomb Jul 9, 2018
    AlexandreP, Jul 9, 2018 :
    Hi!
    Do ROM devs usually distribute firmware files alongside their custom ROM themselves? (I.e. as a separate package, or directly inside the ROM zip...)
    If not, is there a (hopefully, easy) way to only flash firmware components from a full OOS zip? Because, yeah, firmware components would be upgraded when a full OOS zip is flashed, but not very efficient if one will replace it by a custom ROM right after... You kindly shared firmware files, but how did you get them?
    And, is there a way to find firmware revision when not on OOS anymore?
  8. Lancelot_69 Lollipop Jul 9, 2018
    Lancelot_69, Jul 9, 2018 :
    Just google the firmware you want and an XDA thread will show you a list of firmware
    AlexandreP and idkwhoiam322 like this.
  9. idkwhoiam322 Marshmallow Jul 9, 2018
    idkwhoiam322, Jul 9, 2018 :
    No, most devs don't package them and you can quite easily find the firmware zips off the internet. They can be flashed at any time, even if you're on a custom ROM.
    AlexandreP and Lancelot_69 like this.
  10. AlexandreP Honeycomb Jul 9, 2018
    So... I guess someone extracts them from its own OP5, and make it available to others on the Web. Ans not something official from OnePlus.
    Still, good to know! :)
  11. Lancelot_69 Lollipop Jul 9, 2018
    They are official, OnePlus is open source, they release it for this purpose. I think they just don't post it.
