Other Flashlight not bright , only one led enabled
  1. R5Copa
    Cupcake Feb 3, 2019
    R5Copa , Feb 3, 2019 :
    Hi,
    First i thought the flaslight led was broken on my OnePlus 6 .
    Then i noticed only one led is switched on by enabled flashlight.
    The second is working only when taking flash foto.
    Please enable second led with flashlight , or make a switch to do ourself.
    Grtzz
    Rene
    working with 9.0.3
  2. Sharry7
    Ice Cream Sandwich Feb 3, 2019
    Sharry7 , Feb 3, 2019 :
    no both are enabled ...even on torch.
    BTW how did you even noticed this? I got blind for 30 secs after checking my flash led.
  3. R5Copa
    Cupcake Feb 3, 2019
    Hi,
    Noticed it when you see the difference with taking foto in the dark.
    first one led for focus , and then the second does the flash for foto.
    by the way : I had a spot for 30 sec to when I whatched it for a second.
    you can see it with sunglass .
  4. Deactivated User
    Feb 4, 2019
  5. R5Copa
    Cupcake Feb 4, 2019
    R5Copa , Feb 4, 2019 :
    yes , ...but only one used for flashlight.
    that is why some users complain about weak flashlight I think.
  6. W1571741332747
    Cupcake Dec 11, 2019
