[Submitted] Floating navigation bar
  1. Karangetang
    Eclair Jun 29, 2020
    Karangetang , Jun 29, 2020 :
    Title Floating navigation bar
    Device OnePlus7Pro Software Version O2 Stable 200519
    Topic Suggestion
    Photos 1343994-632652a3dffbfc303aa64a20bfb5bed7.jpg 1343995-5e8239fba41a6f39dbac0d06569d16cc.jpg
    Feature Needed Background Description Hey oneplus I would like an option to have the navigation bar to be transparent and get rid of the black and white bars that it currently has. It would make for a more aesthetically pleasant look like on ios. The navigation bar should float over the apps instead of bordering it. You can find such implementation in youtube music and Google photos. And it doesn't require third party apps to support transparent navigation as seen from this module( https://github.com/samchugit/Immersive_Gestural_Nav_Bar ). Hopefully in future updates the immersiveness of the bar is better with apps. The first photo uses the module to make the bar float over chrome. The second photo is the default bar on oneplus. It look even worse in real life because of the curved corners in the 7 pro.
    Any other comments
    GregoryGPT likes this.
  2. GregoryGPT
    Froyo Jul 4, 2020
