2
FM Radio
  1. amartens181
    KitKat Jan 2, 2015
    amartens181 , Jan 2, 2015 :
    Amazon had tunein for free the other day :p
    #81
  2. amartens181
    KitKat Jan 2, 2015
    Spptify ads suck... They are as bad as FM radio...
    #82
  3. 1poipoy57
    Ice Cream Sandwich Jan 2, 2015
    #83
  4. Tornado77
    Donut Feb 7, 2015
    Tornado77 , Feb 7, 2015 :
    It is not about money.. it is about convenience.. You would rather have FM in your mobile than carry a Mobile and an FM Radio as separate devices.. Also note that in India FM is a big draw.. everyone travelling in public transport is hooked on FM during their commute to office etc.
    #84
    Chugz likes this.
  5. drishd
    Honeycomb Feb 7, 2015
    drishd , Feb 7, 2015 :
    FM Radio would have been icing on the cake. But some day some developer comes with kernel which enables FM in 1+1+0xygen=110 possibilities, may be infinite possibilities.
    #85
  6. pacificsword
    Jelly Bean Feb 7, 2015
    pacificsword , Feb 7, 2015 :
    use tunein or soundhound.
    #86
  7. Laamapalmu
    Laamapalmu , Feb 7, 2015 :
    Hard if the ground pins are under the circuit, and still hard even if they were on the sides and they are so small that the solder would probably go on the nearby pins too.
    #87
  8. Tornado77
    Donut Feb 9, 2015
    Tornado77 , Feb 9, 2015 :
    Not a good option.. as it'll cost me for the data.. whereas if it had FM capability it would have been free...
    #88
  9. fab4272
    Cupcake Feb 9, 2015
    fab4272 , Feb 9, 2015 :
    FM radio would be great. Using an internet radio at sporting with live commentary is no good a lot of times, there is a noticeable lag and you end up hearing commentary 3-5 seconds after the event.
    #89
  10. Sudershan007
    Froyo Feb 9, 2015
    #90
  11. RooZx
    Gingerbread Feb 11, 2015
    RooZx , Feb 11, 2015 :
    I also want radio, I've found that it's kernel not hardware fault
    "kernel does not have the needed Qualcomm "IRIS" V4L FM driver at /dev/radio0." do You know any custom rom that has the normal wired radio?
    #91
  12. bhaskar.duvvuri
    bhaskar.duvvuri , Feb 11, 2015 :
    The major issue is, the radio pin is grounded. It means, even if we add it in the kernel, it will still not work.
    Please check this, http://forum.xda-developers.com/showpost.php?p=54945465&postcount=7.
    I know it is not mentioned as hardware-disabled. But looks like it is.
    We are always optimistic that it would work. But, I think it is a dead-end and we should try to accept it.
    More at: http://forum.xda-developers.com/oneplus-one/help/how-to-fm-radio-one-plus-one-t2847158
    #92
  13. sagardani
    Eclair Mar 4, 2015
    sagardani , Mar 4, 2015 :
    I was hoping that they enable FM radio in Oxygen OS. But doubt that seeing above post :\
    #93
  14. mandar.kanade
    Cupcake Apr 4, 2015
    mandar.kanade , Apr 4, 2015 :
    Sony
    NEW SONY SBH-50 / SBH50 STEREO BLUETOOTH HEADSET-MULTIPOINT,NFC,FM RADIO - BLACK
    You can try this from Amazon..goes great with opo
    #94
  15. holzster
    Cupcake Apr 10, 2015
    holzster , Apr 10, 2015 :
    People PLEASE UNDERSTAND - quit telling people to use apps - that is NOT the reason for wanting the FM chip turned on. FM would be used with ZERO data being used. If there is a weather issue & the towers are down you FM tuner could save your life.
    EVERYONE posting one here knows about the apps in the store.
    Moderators QUIT deleting posts about the OPO having the chip, IT DOES the kernel disables it.
    I have had 5 posts deleted by the same Moderator saying it does not -
    #95
  16. xephael
    Cupcake Jul 17, 2015
    xephael , Jul 17, 2015 :
    Agreed. Unfortunately I've found most users on this forum give bad advice, or say things that are absolutely incorrect. Not surprised to hear moderators are censoring and contributing to the problem.
    #96
  17. jimladen
    Eclair Jul 23, 2015
    #97
  18. Harichand_Raghavan
    The Showcase Reviewer Jul 23, 2015
    #98
  19. zillamania
    Gingerbread Nov 3, 2015
    #99
  20. HellsDelight
    Froyo Jun 18, 2016
    pnunez0627 likes this.
