Font issue in one plus 7 pro
  1. tri_venkat
    Cupcake Aug 26, 2019
    tri_venkat , Aug 26, 2019 :
    i am unable to read the bold letters in one plus 7 pro any one knows the solution to rectify it. pls refer the attachment i am unable to read due to this font
    able to read the bold letters in all apps
  2. camohan
    Moderator Moderator Aug 26, 2019
    camohan , Aug 26, 2019 :
    Are you using customised fonts?
  3. tri_venkat
    no bro i am not using any customized fonts. using default fonts only
  4. camohan
    Can you go to settings, system, accessibility and share the screenshot of what is appearing under display section?
  5. tri_venkat
    bro this the screen shot. Now my problem solved. there is a option in the last coloum HIGH CONTRAST TEXT NOW I MADE OFF and everything back to excellent. Thanks i got the idea from you. Thanks for the support
  6. tri_venkat
    i am having one more query can u answer pls???
  7. camohan
    Yes was abt to tell you. Good it is solved.
  8. camohan
    Go ahead.
  9. tri_venkat
    while using vibration option in ONE PLUS 7 PRO mm-mm options only working and other vibration mode like dz-da are not working. is it hard ware issue or software issue. any solution for this issue
  10. camohan
    Can you feel the vibration mode, in settings when you try to choose various options?
  11. tri_venkat
    camohan
    Can you feel the vibration mode, in settings when you try to choose various options?​
    no i am unable to feel any vibration except mm-mm mode
  12. FitEyes26
    Cupcake Oct 28, 2019
    FitEyes26 , Oct 28, 2019 :
    Fonts makes your device more attractive and creates a user-friendly interface. However, most people do not think about changing it and using the default fonts. Your intention is to decorate your device and make it more convenient by making changes. When changing fonts, the entire device is taken into account, including a configuration application, Whats App, other third-party applications, and so on.
    1. Visit the Google Play Store and download Apex Launcher.
    2. Tap Install.
    3. Open the app.
    4. Follow the on-screen instructions and set up the app.
    5. It will ask you to buy a subscription if you are not interested then tap Skip on the top-right screen.
    6. Once you do this, Apex Launcher will take over and activated.
    7. Now locate Apex Settings from the Home Screen.
    8. Go to the Apex Settings.
    9. Select the App Drawer.
    10. Tap Drawer Layout & Icons.
    11. Scroll down and go for Label Font.
    12. Lastly, choose the font style that you like.
    And if you want to know about the latest fonts then visit: https://fontvilla.com/facebook-font-generator/
