3
for anyone with problems with snapchat [oneplus 6]
  1. jjcom
    Donut May 21, 2018
    jjcom , May 21, 2018 :
    For anyone with problems or especially glitches in the Snapchat app using the new OnePlus 6 I suggest that you change it to fullscreen in the "app display in fullscreen settings".
  2. Passelaten
    Cupcake May 25, 2018
    Passelaten , May 25, 2018 :
    I recived ny OP6 today. Was happy to get the phone up and runnig, but when I installed Snapchat I realized there was a problem with the front camera. The front camera is zoomed in and almost useless. Need a way to force the right screen ratio on Snapchat asap.
  3. mclovin5799
    Gingerbread May 26, 2018
    mclovin5799 , May 26, 2018 :
    its sooo zoomed in and has sooo much noise its actually annoying, hope OnePlus will see this and fix it
  4. angielo
    Honeycomb May 26, 2018
  5. Passelaten
    Cupcake May 26, 2018
    Passelaten , May 26, 2018 :
    After further investigation its not only snapchat that is doing this. Also Facebook and Instagram is doing the same thing. They are all using 19:9 aspect ratio. We need a way to force the right aspect ratio we want to use in each app.
    Matxusz likes this.
  6. P1527331863345
    P1527331863345 , May 26, 2018 :
    WhatsApp, Instagram, Snapchat and many other apps are showing this issue :( A few games are not even playable at the moment
  7. G_Paul_Marin_loIw
    Cupcake Jul 25, 2018
    G_Paul_Marin_loIw , Jul 25, 2018 :
    Hi all, not sure if everyone is facing the same issue as me in snapchat but here it goes; whenever I rotate the phone to take a landscape picture, the camera will just blink and not take the picture. Funny thing is when I try to individually send a snap to someone, it'll take the picture .The display mode is on default but when I change it to full screen everything is in check. Just wanted to know if anyone is facing the same camera issue when display is in default mode. Thanks!!
  8. accio_pushkar96
    accio_pushkar96 , Jul 25, 2018 :
    I'm facing the same issue, i tried every possible method. But the problem still persist.
    Unable to click photos in landscape in snapchat.
    Any possible workarounds?
  9. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jul 25, 2018
  10. G_Paul_Marin_loIw
    As mentioned at the very top, going into settings, display, and changing the "default" setting to "full screen mode" seemed to fix the problem for me. I am able to take pictures in landscape when full screen mode is on. not sure why default causes problems but changing to full screen will fix the problem!!
  11. M56
    Cupcake Jul 27, 2018
    M56 , Jul 27, 2018 :
    I did but still the same problem :)
    Can you tell us you snapchat version
  12. kr2000
    Cupcake Aug 10, 2018
    kr2000 , Aug 10, 2018 :
    WhatsApp, Instagram, Snapchat and many other apps are showing this issue.
  13. Deactivated User
    Sep 13, 2018
  14. R1gBoN3
    Cupcake Dec 19, 2018
    R1gBoN3 , Dec 19, 2018 :
    Best thing I found out is to use the Google Camera app and make the cameras record and take pictures in 16:9 ratio. Then you can just send them on Snapchat. Problems is you can't use their filters.
