12
For Auto-Rotate Not Working
  1. Xiaohuamm
    Froyo Feb 5, 2018
    Xiaohuamm , Feb 5, 2018 :
    In case anyone else notices auto-rotate not work well, here's how I fixed mine. Hope it helps someone!
    1) Dial *#808# in your dialer
    2) In the menu, go to the "Device debugging" tab and scroll all the way down
    3) Set your phone on a flat surface and press "Sensor self-test and calibration"
    4) Tap Gyroscope and Accelerometer options about 5 times each
    5) Try it out!
    Originally suggested by user @codyjames223 on the OnePlus forums.
  2. bboylaiiz
    Donut Apr 25, 2018
    bboylaiiz , Apr 25, 2018 :
    I can confirm that it works after sensor calibration! It was a really annoying issue. Thanks a lot!
    Xiaohuamm likes this.
  3. Xiaohuamm
    Froyo May 13, 2018
    Xiaohuamm , May 13, 2018 :
    ur welcome bro
    bboylaiiz likes this.
  4. Ludo_Mansio
    Gingerbread May 22, 2018
    Xiaohuamm and bboylaiiz like this.
  5. sreenesh 1980
    Cupcake Jun 5, 2018
    sreenesh 1980 , Jun 5, 2018 :
    Friend it worked, I tried to reset the phone earlier without any luck.
  6. krishankumar77
    Cupcake Jun 7, 2018
  7. airness456
    Cupcake Jul 20, 2018
    airness456 , Jul 20, 2018 :
    Still doesn't Work for me. The screen rotation is not working at all, I tried everything you said, even reboot multiple times and nothing.
    Here what it looks After doing the calibration, everything works but the last option accelerometer
  8. zWhoHeBe
    Cupcake Jul 24, 2018
    zWhoHeBe , Jul 24, 2018 :
    Same exact thing for me .High bias. Please escalate OP! Using OP6. Issue happened with update to 8.1
  9. N1534337645140
    Donut Aug 15, 2018
    N1534337645140 , Aug 15, 2018 :
    my OP6 same problem auto rotate not working....but ur information is very helpfull...now its work ... good ...thanks a lot .
  10. mazzu
    Cupcake Aug 21, 2018
    mazzu , Aug 21, 2018 :
    Thank you so much, it works! Months with rotation problem till I found your post...
  11. H1518223333858
    Cupcake Feb 10, 2019
    H1518223333858 , Feb 10, 2019 :
    Hi OP5
    My auto rotating not working have tried above all option but still no luck, m after doing calibration test for sensor getting failed test in accelerometer bmi160
    Request your help to fix it
  12. J1538667611487
    Eclair Apr 14, 2019
    J1538667611487 , Apr 14, 2019 :
    my op6 also shows the same and auto rotate is not working. did you get yours fixed?
  13. dibyendu.cts07
    Cupcake Jul 3, 2019
    dibyendu.cts07 , Jul 3, 2019 :
    I am facing same issue. I followed the above steps but I am also getting error message as "high bias". I have done factory reset but still same issue.
    Can someone tell what to do next?
  14. dibyendu.cts07
    Cupcake Jul 6, 2019
    dibyendu.cts07 , Jul 6, 2019 :
    Yesterday I have received oxygen upgrade and after upgrading, auto rotation is working fine. After upgrading, just do the steps as mentioned above. Like *#8088# then "Device debugging" tab and so on. Thanks for your support.
  15. Deactivated User
    Jul 30, 2019
  16. susajsnair
    Cupcake Oct 10, 2019
    susajsnair , Oct 10, 2019 :
    i have this issue with my OP7, and i couldn't get any response when i dial *#808#. can someone help
  17. twinnmann
    Cupcake Dec 16, 2019
    twinnmann , Dec 16, 2019 :
    Any update on this? I'm having slow rotation responses with my 7T pro. I too, cannot dial the number.
  18. olly2009
    Eclair Jan 22, 2020
  19. D1579905019308
    Cupcake Jan 24, 2020
    D1579905019308 , Jan 24, 2020 :
    That really works ... Thanks
  20. G1589222368436
    Cupcake May 11, 2020
    G1589222368436 , May 11, 2020 :
    Hi, when I open the diaper and type *#808# it doesn't do anything. It erases what I typed and is just back to the dialer... What do I do? My auto rotate hang been working for a while
